Old 08-03-2003, 12:02 PM
mattski mattski is offline
Suspension knock fix?
I have read several threads about knocks coming from the suspension but fortunately my SVX does not suffer from that. However, my recently purchased 93 Legacy did. I replaced all the struts but it did not help. I was ready to tackle the ball joints but someone had suggested greasing the bushings which hold the anti-sway bar to the frame. It worked like magic! No more nasty knocks. I thought I would share this experience which may also apply to the SVX.
Mattski
97 LSi Ebony Pearl 130k Midlife Crisis
93 Legacy Wagon 180k Training Wheels
98 Outback 180k
98 Dodge Durango 120k Ski Bus
A multitude of skis to feed my need to go faster, faster until the thrill of speed overcomes the fear of death.
Old 08-03-2003, 07:54 PM
svx_commuter's Avatar
Hi Matt,
I thinks it's a great idea. Thanks for sharing. I would like to know if anyone else has had this fix work on the SVX.
John
SuperbVehicleXtraordinary
Proud sponsor of a 1992 SVX.
Old 08-03-2003, 08:19 PM
lee lee is offline
I can confirm a bushing going bad can produce a suspension knock - the bushings are cheap - and it doesn't have to be totally eaten up to make the noise.
what did you use to grease the bushing? Of course, lately my front seals are leaking so the bushings are getting all the "greasing" they can stand
Old 08-04-2003, 06:13 AM
The bushings were not eaten up at all, just dry. They were D shaped with the flat part up against the frame. I used bearing grease.
Mattski
98 Outback 180k
Old 08-30-2004, 10:00 AM
dcarrb dcarrb is offline
another thread revival
I removed and greased my rear sway bar bushings yesterday, with the aim of eliminating an odd, muffled thunk that often occured (note past-tense) when the weight of the car shifted. Didn't notice it on the way into work this morning, so hopefully this is another story of a search here resulting in an easy fix. Thanks.
dcb
Old 08-30-2004, 07:58 PM
n00b on demand's Avatar
I also get a knock from my suspension or so i thought....i looked over at the passenger seat while driving and it jiggled going over bumps causing it to make a knocking noise
Old 09-01-2004, 03:12 PM
alia176 alia176 is offline
On something like bushings, try using silicone grease vs wheel bearing grease. Wheel bearing grease and rubber won't play well in the long run. The rubber will degrade faster this way. Just a thought.
Ali
'92 SVX LSL
'03 4Runner
'96 FZJ80 Landcruiser
'90 Mercedes 300E
Old 09-01-2004, 05:32 PM
BoondockSVX
Ali
Silicone doesn't work as well, since it's 'thin'. Lithium or Bearing grease works a whole lot better, but it's also bad for the rubber, causin the bushing to expand and deteriorate even faster.
Best bet is to get some polyurthane swaybar bushings from Energy suspensions, and use the grease that comes with the kit.
- Jim
Old 09-02-2004, 07:11 AM
I wondered about that as I slathered-on the wheel bearing grease. Guess I'll just monitor the condition of the bushings and see what happens. That definitely was the culprit, though; haven't heard the noise again. Curiously, the bushings were in near-perfect shape (at least visibly), with no deformation, cracks, or obvious deteroriation. Apparently the sway bar would simply load-up and bind in the bushings, and when the weight of the car shifted the other way, the tension released with a very noticable thunk.
dcb
Old 09-04-2004, 09:43 PM
Peach
thunkin
My 92 has that thunk and if the grease thing works I will be very happy, and grateful for all the remedies you SVXers have produced.
