Old 07-31-2003, 09:11 AM
phalg
Question air filter install
I would like to install a new air filter in my 1992 SVX. Can someone give me instructions for doing the job? What kind of air filter should i purchase at, say Autozone? Is it easy to replace the filter?
thanks,
Phal
Old 07-31-2003, 09:27 AM
svx_commuter's Avatar
Well tell the AZ counter guy: make, year and model, buy the filter. Also available at Walmart. Open the hood, remove connector/wire for the MAF, remove the 4 clamps that hold the top of the filter "box" on, remove the top and replace the filter. You will have to wrestle the top off while bending the hose. Easier on a hot day than cold. Or the hose can be removed at the MAF. The filter "box" is on the passenger side. The air filter is rectangular in shape about 1.5 inches thick. See if someone can help you with some basic instruction. It would be a good idea if you haven't done naything like this before. Remember you have to start somewhere if you want to do the work yourself.
SuperbVehicleXtraordinary
Proud sponsor of a 1992 SVX.
Old 07-31-2003, 12:00 PM
nubs's Avatar
nubs nubs is offline
Multiple Suby Owner
Don't forget to clean any debris out of the airbox before you put it back together.
Old 07-31-2003, 05:59 PM
awdsvx awdsvx is offline
K & N Oil Filter
Buy a K & N Oil based filter. I hate cleaning it, but I think, it's worth it.
Old 07-31-2003, 07:02 PM
lee lee is offline
Re: K & N Oil Filter
For a novice, I disagree, the K&N requires application of a spray-on oil. Too much can be sucked off and coat the MAF sensor causing rough running, too little yields inadequate air flow cleaning/protection.
For my old car (Toyota MR2 turbo) the K&N definitely produced less power in several dyno tests when compared to the OEM paper rig (did not test Fram, etc). I do use a K&N on my motorcycle though, so I don't believe I'm overly biased. To my knowledge, no one on the SVX site has done a before & after test with anything more than "seat of the pants" test rigor.
Old 08-01-2003, 12:12 PM
phalg
novice
Excuse me for being a novice... Can you elaborate on what MAF stands for? And what is the difference between K&N and other kind of filter? Being a beginner, I'd like to go for the one thats easier and cheaper.
thanks for your responses.
Phal
Old 08-02-2003, 10:14 PM
Motorsport-SVX's Avatar
Motorsport-SVX Motorsport-SVX is offline
check out www.planetsvx.com
for starters
MAF is for Mass Air Flow sensor, the round tube
with wires going to it bolted to the square box..
Std paper filter is just paper....
K&Ns are cotton gauze with slightly oil treated..
flows more air, traps more dirt.....and washable.
You can see more at K&Ns website.....
http://www.knfilters.com/
You can check out our online store for some other
options too....
Links below
My mom will forever live in me and
never be forgotten, one day Ill see her again
CLICK the LINK below to Visit the SVX Store:
http://www.planetsvx.com
http://www.motorsportwarehouse.com/svx/sig2.jpg
Cars in the garage:
92 Toyota Soarer Single Turbo JDM RHD
70 Boss 302 Mustang 39k original miles
97 SVX Lsi
92 Liquid Silver Murano-ized (1st of its kind)
71 Cougar Xr7 Conv 351c 4v 4spd
69 SS Camaro 350
71 Nissan RHD Fairlady Z
70 Stang Fastback
70 Amc AMX 390
71 240z
89 Conquest TSi w/ 5.0 v8 swap
84 Mustang GT Turbo conv
"good, if it bleeds, we can kill it ....."
Old 08-03-2003, 05:48 AM
Green1995SVX
Subaru recommends only using non-oiled filters on their cars because the oil can damage the MAF sensor.
Mike
Old 08-03-2003, 11:41 AM
Mike
Ive heard that about 1000 times.....While at SEMA a few yrs
ago I talked to a K&N rep in person about that......
they in a word "chuckled" and assured me their (or any filter like it) wouldnt be a problem.
Cleaning your MAF sensor is easy anyway if you want to..
Just remove it every 6 months if you want and carefully run
a gentle stream of warm water for a few minutes over the
wire inside. I dry mine off with a blow drier from about
a foot away with a mild stream of warm air, and re install it.
But I have never seen any cars have a real problem yet with any K&N style filter.
Cars in the garage:
97 SVX Lsi
69 SS Camaro 350
70 Stang Fastback
70 Amc AMX 390
71 240z
Old 08-05-2003, 01:45 PM
svxlatino
Thumbs up K&N
I have used K&N filter for over two year and never have a problem. But just a few month ago I changed it to the cone type filter in red color, it look good. I just had to do a few minor adjustments but I'm pretty happy with it. I'll post pictures soon.
Old 08-06-2003, 05:34 AM
SVX10's Avatar
SVX10 SVX10 is offline
Fighting with electricity
I lost my MAF while running an oil type filter. Not saying it was necessarily the oil's fault, buuuuut....
