Old 07-24-2003, 02:29 PM
IwantaSVX IwantaSVX is offline
Send a message via ICQ to IwantaSVX Send a message via AIM to IwantaSVX
Dragging noise?
My car has been making this noise since I had the AWD rebuilt. When it shifts from 1-2 there is this loud dragging noise coming from the rear of the car. I can also hear it ever so slightly if I turn a corner sharp.
I think it has something to do with having the AWD repaired, so I called to get it in to the dealership. I tried doing tight figure 8's and someone suggested. I do NOT feel the car hop like it is binding BUT the tires squeel. Its not like I was going 50mph either. I have also noticed that if I turn out of a parkiing spot tight, every once and a while, I can feel or hear one of the back tires break loose.
No blinking power light or anything.
Old 07-24-2003, 04:40 PM
Re: Dragging noise?
It does sound like the AWD is binding. Try fitting the FWD fuse to see if it changes.
Old 07-24-2003, 04:47 PM
If it is binding, it certainly does not act like binding that I have experienced before. I drove a '95 Legacy that binded and certain times it felt as if the back end would hop or skip around corners/turns.
I also can't explain the noise on the 1-2 shift. It gets louder the higher the RPMs. I do not hear it on any other shift.
Old 07-24-2003, 05:51 PM
If the fuse does not change it. Have a look at the rear tranmission mount, it may be allowing the drive shaft to move and touch something when the load is on.
