Old 07-17-2003, 10:37 PM
Henry
Why won't my driver's seat go forward?
Perhaps there's a coin in the mechanism, but the driver's seat will no longer swing forward more than an inch or two.
I'd love to see a couple of ideas before I pull the seat (PITA).
Old 07-17-2003, 11:42 PM
Rotorflyr's Avatar
Will it move back? Or do you already have it back as far as it will go? If you don't, try moving it back, and looking in the tracks for something that may be blocking the movement.......
Old 07-18-2003, 04:27 AM
Re: Why won't my driver's seat go forward?
Hey, Henry,
If it's a PITA, you have to be using way too much electricity down there.
Old 07-18-2003, 08:19 AM
Henry
The seat moves normally in the 'electric' mode - it both slides forward/back, and reclines.
However, it's impossible to get into the back seat from the driver's side because when the release lever is pulled, the seat moves only an inch or two.
Old 07-18-2003, 10:12 AM
alacrity024
eh, just take the thing out.. you'll probably find about two dollars in change
-adam
Old 07-18-2003, 03:30 PM
greg
When did it ever swing?
I don't know about anyone elses, but none of my SVX's have ever had a "swing" drivers seat. The only way I have been able to let people in the back seat is to push the button and let it slide forward.
If it was me Henry, I would be more worried about the 1-2 inches it does slide.
I could be wrong....
-G
Old 07-18-2003, 04:14 PM
SubaSteevo's Avatar
No longer blue member
It is supposed to swing
SVX'in when you pull the lever on the top left of the drivers seat it is supposed to swing forward (I'd say it makes like a 75 degree angle when pulled). Henry, you remember dropping anything?
-Steve
01' MSM Lexus IS300
Old 07-18-2003, 04:43 PM
Henry
Dropping anything?
Sure! When the nitrous was installed the acceleration emptied my pockets more than once!
You're right - there's something lodged in the mechanism. Though I hate pulling that seat, I'll do it tomorrow for the money, and the weight reduction will probably help performance.
