Old 07-15-2003, 12:56 AM
FifthElement
Brake Questions
I recently had an emmisions inspection. On the invoice it states my rear brakes are at 5/32 and my front brakes are at 11/32.
What is that measurement? Is it the actual pad? And should those pads' measurements vary so drastically?
Old 07-15-2003, 06:01 AM
nubs's Avatar
nubs nubs is offline
Multiple Suby Owner
Re: Brake Questions
Originally posted by FifthElement
I recently had an emissions inspection. On the invoice it states my rear brakes are at 5/32 and my front brakes are at 11/32.
Those numbers are the actual friction material thickness in fractions of an inch.
Front pads usually have more material than the rear to begin with but it really does not matter if they are different. Also the fronts will wear faster than the rears will.
Old 07-15-2003, 09:28 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Yeah, what Nubs said
Somewhere along the way someone may have put new pads on the front and not replaced the back pads
Question - what were they doing inspecting the brake pads during an emissions check?
Retired NASA Rocket Scientist
Center Network Member #989
Old 07-15-2003, 09:44 AM
FifthElement
Yeah, that makes sense.
They performed a 27 point safety check, is what it says, free for my safety. They also noted my tire treadware and that my differential fluid is dirty and other such things.
I'm wondering, anyone know what measurement should denote replacement of the pads?
Old 07-15-2003, 09:48 AM
SVXRide's Avatar
If I remember correctly, there is a wear indicator (basically a small piece of metal that will come into contact with the rotor once the pads wear down) that will give you an audible indication that it's time to replace the pads. The SVX's pads are so easy to change that it's almost criminal to pay someone to do it for you
-Bill
Old 07-16-2003, 01:32 AM
Why did you get an emissions check? Are they required where you are? Or was this part of the 27 point safety check?
Old 07-17-2003, 10:47 AM
BradT
If I remember correctly, there is a wear indicator (basically a small piece of metal that will come into contact with the rotor once the pads wear down) that will give you an audible indication that it's time to replace the pads. The SVX's pads are so easy to change that it's almost criminal to pay someone to do it for you.
Now, would that indicator be something different from the super-high-pitched squeal that frequently occurs when I tap on my brakes?
You know ... I'm wondering if, at 74,000 miles, I'm about due for resurfacing. (And then there's the weird bird-like chirping I hear from the rear brakes when I first drive off in the morning -- with the brakes unapplied -- as if a caliper wasn't releasing correctly.) Eh, I'm no brake expert, that's for sure.
Old 07-17-2003, 12:08 PM
SVXRide's Avatar
Yep, "super-high-pitched squeal" would be it
Sound from the back could be the emergency brake not fully releasing or, as you've noted, the caliper not releasing correctly.
Old 07-17-2003, 04:56 PM
flynavy
i'm actually about to replace the brake pads and want to try it myself. does anyone have anything in their lockers on replacing the svx pads? that's not the first time i've heard they are very easy to replace on this car.
Old 07-17-2003, 05:18 PM
nordique14's Avatar
Who watches the watchmen?
Check out Ryan's home page. He has some SVX how-to's on there. There's a good one on how to do the brakes.
http://www.ryanmacdonald.com/car/howto/howto.html
He uses the "bolt method" to get off the old rotors that are stuck on. I used the "WD-40 method". It involves using lots of WD-40, waiting about 5 minutes and hitting the rotor with a rubber mallet.
Good luck,
Old 07-17-2003, 05:36 PM
kuoh kuoh is offline
The bolt method is actually pretty fast & simple and coincidentally, the four bolts that hold the two upper radiator brackets have the exact thread and length needed. Just "borrow" a couple of them to pop the rotors off then put them back. And if you're doing the rear rotors, don't forget to release the parking brakes.
KuoH
