Old 07-16-2003, 11:07 AM
Originally posted by Porter
I had the opportunity to watch my SVX at 100mph on the highway on Sunday... the rear wheel gap actually shrinks slightly at speeds over 80 so I assume there is usable downforce being created.
Would you have the same opportunity to see it at speeds over 100 mph? What springs do you have?
Old 07-16-2003, 11:12 AM
Porter
Not sure what you mean about opportunity... I guess so, I can just have a friend drive the car for me.
The springs are Eibach linear race springs, from Ground Control. It's the Koni/GC setup.
Old 07-16-2003, 04:06 PM
Ok, I didn't know where you got the pics. Thanks for the info on the springs.
Old 07-16-2003, 06:43 PM
immortal_suby's Avatar
Thread Killah
I guess you could yank the telltales off your jib and stick them to the spoiler to check the airflow.
Locker Link
2015 BRZ Limited 6MT
Old 07-16-2003, 06:52 PM
kuoh kuoh is offline
Get a string and marker and check again. The linear distance from fore to aft of the upper and lower surfaces are nearly identical at the center of the spoiler.
As for the wind tunnel tests, I've never seen or heard of them mentioned here or on Yahoo.
KuoH
Originally posted by NomadTW
the wing is NOT symmetrical from top to bottom
it is actually an airfoil flat on top curved underneath
i have heard that in the wind tunnel tests it is functional at high speeds, over 100, which i believe,
Old 07-17-2003, 01:16 AM
Alycone's Avatar
Alycone Alycone is offline
Sue isn't really striped
Originally posted by mbtoloczko
I happen to live in an area where there are frequent opportunities to drive at 100+ mph, and I've taken advantage of it.
Would this be in eastern WA? If so, I'm crossing the mountains.
Old 07-17-2003, 09:47 AM
mbtoloczko's Avatar
sans SVX
Yep. The roads are relatively empty, especially the backroads. I still get totally paranoid of cops when I drive at those speeds. :-)
Mychailo
Visit my locker
