Old 07-07-2003, 11:35 AM
SVXGIRL182 SVXGIRL182 is offline
smoke
after I drive my car smoke comes out the drivers side wheel well. Its bluish and smells really hot, its not from overheating brakes, it smells oilish. I also have a leaky seal and I had an estimate done that the guy said it would be 550 for both seals and a timing belt. Does anyone know if the smoke would be from that and if that is a good price?
thanks!!
See my car @ http://www.nicez26.homestead.com/NicolesPage.html
Old 07-07-2003, 01:05 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
smoking
Tell your car smoking is bad and it should quit today! Sounds like you have oil dripping onto your exhaust creating the hot oil smell and the smoke. You did check your axle though right? The boots are not cracked? If they are you'll have a lot of grease in there from that you'd be able to see.
Old 07-07-2003, 02:43 PM
its not any of those things. There is only on the bottom of my car, I think from the leaky seals.
Old 07-07-2003, 02:44 PM
sorry i meant oil on the bottom of my car.
Old 07-07-2003, 02:48 PM
benebob's Avatar
If it is leaking oil 90% of the time it will make it onto the exhaust pipe somewhere along the line. A friend's impreza did the same thing and his cam seals were leaking, going down to the bottom of the t belt cover and then when he drove it would get pushed back right where the exhaust starts. It is easy to spot. You'll have a dark colored area on the exhaust.
