Old 06-29-2003, 02:54 PM
96svxer
What is this, and How Do I get it Off?
I have a high pitch noise comming from my Drivers side rear. I touched my rim and burned my self on it. So after loosening my parking brake I figure it has to be bearings? It's not a dull grinding noise which I associeate with bearings, more of a high pitch sqeel when driving. My Calipers seem to be moving fine and whith that kind of heat it has to be bearings right? Well I removed the entire knuckle from my car but one cable and cant figure it out. Please help me! How do you remove it?
Mystery Cable
Old 06-29-2003, 03:36 PM
lee lee is offline
the mystery cable is the sensor for the ABS. use multiple PB Blaster applications and try wiggling it so it comes free. Careful. I understand they're expensive.
Old 06-29-2003, 04:04 PM
96svxer
I have tried numerous shots of WD40 but It seems like it doesn't want to come off. Is there a bolt, weld or lock anywhere? Do I need to take this off to get the bearings out? AHHHHH the fustration!
Old 06-29-2003, 04:31 PM
lee lee is offline
there is a bolt on the back side if I remember correctly. WD 40 is not as good as PB Blaster - WD40 is mostly an aerosol oil while PB does a better job at penetrating and breaking down rust 0 which is usually what causes the sensor to freeze up. You might look at the other end of the cable that comes out the other side - see if it can come off from there. Also search for rear bearing replacements. Some won't be of any help, but I remember a few talked about frozen/rusted parts.
Old 06-29-2003, 05:03 PM
If your wheel is that hot, it is much more likely to be brakes than bearing related.
You might have a sticking calliper, or a stone lodged in the brakes.
Also, maybe your handbrake shoes have seized on or something. They are in the rear hub.
Old 06-29-2003, 06:41 PM
dekidd7457
If you can't get the sensor out of the knuckle then just unplug the sensor from the harness. You may have to go under the rear seat to get to the connector but it's worth it. The sensor is expensive. You'll need a press to get the bearing in and out.
Old 06-29-2003, 06:46 PM
dekidd7457
The sensor is $115 at SubaruPart.com so be careful !
Old 06-30-2003, 06:14 AM
96svxer
Yeah found that bolt. Removed it. The funny thing is my car has no rust. All the bolts came off fine. But the darn ABS sensor is still stuck. Even got a pair of pliers on it to try and wiggle it out. One more question
It seems the ABS sensor is "plugged" into a small light colored "mount" that you can see easily in the second picture which is bolted to the dust guard. Does this entire mount come off of the dust guard, or does the abs sensor pop out of the mount? It would make sense the bolt would free the ABS sensor/mount combination, but it seems like it is welded to the dust shield.....Or is this just rust?
Old 06-30-2003, 06:16 AM
96svxer
I thought it was the brakes too at first, but everything seems to be in check. Took the calipers out, everything looked fine, seals all in good shape, pads are brand new. I cleaned all the parts/pads. I adjusted the parking brake cable so it was extramly loose and wouldn't engage, the shoes look fine. I cleaned and greased all sliding parts. I'm stumped?
Old 06-30-2003, 06:25 AM
Andy's Avatar
Andy Andy is offline
Send a message via Skype™ to Andy
Re: What is this, and How Do I get it Off?
Can I resist the temptation?
Nnnngggrr Nnnnngggrr
Could be children reading
Larry could see this
Phew, temptation resisted
Andy
If I would be a young man again and had to decide how to make my living, I
would not try to become a scientist or scholar or teacher. I would rather
choose to be a plumber or a peddler in the hope to find that modest degree
of independence still available under present circumstances.
-- Albert Einstein, The Reporter, November 18 1954
Old 06-30-2003, 10:51 AM
svx_commuter's Avatar
The double meaning removed.
LOL
No confusion now....
I have a high pitch noise coming from the left rear of my SVX. I touched the wheel rim and burned my hand on it.
SuperbVehicleXtraordinary
Proud sponsor of a 1992 SVX.
