Old 06-27-2003, 04:55 PM
RUMRUNNER
Angry door lock
Went to pick my car up after AC fix and drivers door will not unlock. Can you removal door panel with the door open. If not any ideas on how to open door. Runner
Old 06-27-2003, 06:00 PM
Subafreak's Avatar
Superbeast
I don't think it would be posible with out destroying it, there are two screws that are behind the side of the dash. Will the door not unlock or just not open?
Old 06-28-2003, 05:31 AM
RUMRUNNER
The door will not unlock. The key turns in the door but the lock seems stuck. Runner
Old 06-29-2003, 12:16 PM
SHISVX SHISVX is offline
did you try removing the panel and the plastic and lubing the lock mechanism? that works when my lock desides that it doesn't wanna work.
Kelli
i can tell you how i did it if ya want
Previous owner of the
Princess Pearlie "Dimples"
as of 8/6/03
1992 LS-L Pearl 124k
"Yeah, that thingy!"
owner of the new 1992 LS-L Pearl "Susie"
I am a pessimistic optimistic. I think the worst is going to happen, that way when it does, i don't feel as bad, but if the best happens, i am twice as happy.
Old 06-29-2003, 02:21 PM
RUMRUNNER
Thanks Kelli. I took it back and they fixed the door but now my seat belt doen't work. It's stuck in the door open position. Can I move it some way to the closed spot until I fix it. Runner
Old 06-29-2003, 07:24 PM
Subafreak's Avatar
Superbeast
In the bottom of your center consol should be an allen wrench, somewhere in the B-piller cover should be a hole with a cover on it. Remove the cover insert allen wrench and turn in the direction that makes the seat belt latch move in the desired direction. Or take it back again and ask what the hell they did to it now.
Old 06-30-2003, 01:12 PM
RUMRUNNER
The spot is under the back seat for the allen wrench. I found out the senser in door was broken and will have it replaces tomorrow. They disconected the senser so the door lock will work. They just forgot to tell me. Runner
