Transmission computer question
Can a 1997 TCU be used in a 1996? Both are OBD 2 so I assume the wiring is the same.
Re: Transmission computer question
I'd assume so, but to confirm you could look up the part numbers for both on one of the online Subaru parts sites and confirm that they match?
96 is a split year so makes sure you get the correct one late 96 not a MQ
