Re: Custom DIN slot cup holder
No but it can be easily pulled out and stored somewhere if necessary. Because it is clear and shaped the way it is, it has no impact on radio stuff when there isn't a cup in it. The foam rubber pieces have just the right amount of stickiness to keep it in place while not being too sticky to make it difficult to be removed. They are also stiff enough to easily support a full travel mug of coffee but not too stiff to make it difficult to insert into the pocket.
