Old 10-13-2012, 01:31 PM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
Help diagnosing my cranking?
Hey all, it's been a while since I've been posting but so close to getting my car up and running.
My engine is back in but my cranking does not sound normal. I double-checked my timing marks to make sure it wasn't off and reconnected all my cables.
It's definitely getting fuel and has a new starter and battery. There is definitely oil in the motor, it has new plugs and I double checked the harness behind the motor. It seems to be going from slow crank to fast crank back to slow. Any thoughts?
Below is a video of the cranking behavior.
http://youtu.be/1HU59M1_11k
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 10-13-2012, 01:58 PM
Re: Help diagnosing my cranking?
Does it ever start? Have you checked the battery voltage? Sounds electrical.
Old 10-13-2012, 02:42 PM
I would first strongly suggest taking a look at the battery-chassis ground, the battery-engine ground, the smaller engine-chassis ground up by the dogbone mount, and the battery terminals.
Does it start eventually?
Old 10-13-2012, 03:15 PM
Tim's Avatar
Tim Tim is offline
It doesn't start at all.
Tim
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 10-13-2012, 03:28 PM
Still sound like motor is fighting the starter. Have someone else check the timing with you . Second opinion.
Old 10-13-2012, 05:46 PM
redlightningsvx's Avatar
Collision Refinishing Tech
is the starter fully seated on the bellhousing?
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
oab_au oab_au is offline
Yes it sounds like the belt is timed wrong.
One Arm Bloke.
Tell it like it is!
Old 10-14-2012, 06:44 AM
Tim's Avatar
Tim Tim is offline
Thanks everyone I will check out the grounds and timing, then report back!
The start is seated properly, it is bolted in as far as it will go.
Tim
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 10-14-2012, 11:59 AM
Tim's Avatar
Tim Tim is offline
I took a look and found an unhooked cable near the dog bone. Not sure what this goes to or if it's supposed to be unhooked since i have a manual trans?
Tim
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 10-14-2012, 12:46 PM
If you've got access to a spare starter you could swap it in and see what happens. My old auto starter gradually weakened over the summer a couple years ago to the point it would barely crank the motor. This isn't the common failure mode for starter (usually they just kick the bucket over night), but does happen.
Have you tried bump starting the car?
Edit: Also, try throwing a breaker bar on the crank pulley bolt and turning the engine by hand to see how easily it spins. It should take modest effort, but nothing herculean.
Old 10-14-2012, 02:00 PM
That is the "smaller engine-chassis ground" I was referring to. I have seen posts in the past that not having that resulted in a non-start (I think most likely the other ground was also weak/corroded, but restoring the smaller one was sufficient to fix the problem.
So, how do the other grounds look? I'd try adding an extra engine-battery ground and see how it does.
Old 10-14-2012, 05:08 PM
That wire is the ' engine to body' ground, it runs from the back of the block to the firewall, should not affect the starting as the starter has its own ground, but plug it see what gives.
One Arm Bloke.
Tell it like it is!
