brake flush
how much fluid do i need to completly flush my brake system?
Re: brake flush
One quart should be enough for a flush.
I use Valvoline 3-4 full synthetic.
Re: brake flush
Agree with OT. Unless you are one of the 1 percent who actually do it ever 2 years I would use nearly all of the bottle since it is useless after opening anyways.
Re: brake flush
if you want to be sure you got a complete flush they sell colored fluid in several different colors. just be sure not to get dot 5 which is almost always colored.
Re: brake flush
I use the ATE Super Blue Racing Fluid, DOT4. Has a much higher wet and dry boiling point. Boiling point minimum: 536 degrees F Wet boiling point minimum: 388 degrees Designed to last up to 3 years under normal highway driving conditions It comes in the blue color. I alternate between this and the ATE TYP 200 Amber fluid (which has the identical specs) when flushing the brakes to see the color change at the calipers. That way I know all the fluid has been changed. .
Re: brake flush
the reason why i'm asking is cause i looked at the fluid in the master cylinder and it looks all dark which if i'm not mistaken brake fluid is normally clear
Re: brake flush
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 10-14-2011 at 04:52 PM. |
Re: brake flush
hmm weird the fluid i got for my clutch master cylinder it was clear
Re: brake flush
Most are more clear than amber.
Re: brake flush
Re: brake flush
and a Minimum Wet Boiling Point of 311°f. Stock is DOT 3; Boiling point ranges [2] Dry boiling point Wet boiling point DOT 3 205 °C (401 °F) 140 °C (284 °F) DOT 4 230 °C (446 °F) 155 °C (311 °F) DOT 5 260 °C (500 °F) 180 °C (356 °F) DOT 5.1 270 °C (518 °F) 190 °C (374 °F)
Re: brake flush
Yellow: http://www.tirerack.com/brakes/acces...tail.jsp?ID=22 I got it from here. It's good stuff.
Re: brake flush
i used ate in all the track cars i built, never had someone boil it
Re: brake flush
He has been known to wear out a brand new set of brake pads in one day. Tech inspection requires brake fluid be less than 6 months old, but is probably flushed more often than that. Harry swears by this stuff. Now using it in his 92 pearlie for autocrossing and other track events. I still flush mine yearly. I never approach the boiling point, but even the best stuff is hygroscopic (absorbs moisture). .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 10-17-2011 at 10:14 PM. |
