Old 07-02-2011, 01:10 PM
taylorbr's Avatar
taylorbr taylorbr is offline
Pics of Fuel Pump Relay??
Does anyone have pictures of the fuel pump relay and where I can check for voltage?
I'm having a crank/no start issue which is fuel related. Used starting fluid and it starts and runs for a few seconds. Now I'm trying to diagnose whether it's the relay or the pump. Under the dash is a fustercluck of wires which is why I'm hoping that a picture will help sort things out.
Thanks much!
'93 Legacy LS (will last longer than the cockroaches)
'94 SVX LSi
Old 07-02-2011, 02:45 PM
michael's Avatar
michael michael is offline
What Potholes ???
Re: Pics of Fuel Pump Relay??
Best I can do on short notice
Wanted: Steering Wheel
Old 07-02-2011, 05:40 PM
Cam Cam is offline
The fuel pump relay is under the rear parcel shelf. Not under the dash. You must partially disassemble the trunk interior to reach it.
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
Old 07-02-2011, 06:20 PM
Hocrest's Avatar
Hocrest Hocrest is offline
Freezepop's are Awesome!!!!
The fuel pump modulator and fuel pump resistor are under the parcel shelf in the trunk. The fuel pump relay that Michael pictured is up under the dash, near the ECU/TCU.
Old 07-02-2011, 07:04 PM
Cam Cam is offline
You are correct. I read relay, I typed relay, but I thought resistor. My bad.
Cam
'92 Ls-L Dark Teal
Old 10-16-2011, 09:35 AM
Austin Austin is offline
...The fuel pump relay that Michael pictured is up under the dash, near the ECU/TCU.
For anyone interested, I'm picking up one today from Advance Auto Parts:
BWD Relay Part # R3054Z
I'm sure it can be found at any parts store, but I wanted to post this so people could see a picture of the actual part. Also, apparently it's a REALLY common relay as it's used in a ton of common makes (Toyota, Honda, Mitsubishi, etc.)
(not to be annoying, rather to be helpful, I'm going to cross post this in some other fuel pump relay threads just in case anyone is searching...)
FWIW, turns out it was a loose ground wire on the FP module in the trunk.
Austin
__________
'97 LSi Ebony - daily driver - mostly just needs body work [couple o' rust holes, door dings, and peeling clear (of course)]
'96 LSi, Laguna Blue (retired - soon going to a new home)
'89 XT6 5 speed (Gone but not forgotten)
