Old 05-03-2009, 08:51 AM
evilsvx's Avatar
evilsvx evilsvx is offline
broken radiator? or bad headgasket?
ok so my svx is overheating. my cousin says its the radiator but my friend says its the headgasket. the problem is that on the highways it stays on normal level but when i get out of the highway it starts overheating. when i open the cap from the radiator, there is a white pinkwish mix but when i checked the engine oil is clean. it does not loose that much antifreeze but it still overheating. is there any place where they can test my radiator so i dont have to buy another one? thank you
Old 05-03-2009, 09:06 AM
Wikedjuggalo's Avatar
Rebuilding
Re: broken radiator? or bad headgasket?
I have a similar problem with my Barcelona. I have not found the problem for whats its worth I replaced both my radiator and thermostat and that did not solve my problem. I plan on pulling the engine sometime and see what it could possible be.
Old 05-03-2009, 09:58 AM
Headgaskets, you need to do them
Old 05-03-2009, 10:03 AM
evilsvx's Avatar
i did changed the thermostat and it did not overheat for like two days but the next day it began the problem again
but wouldnt be like antifreeze on the engine oil too? how much do you think will be labor. i already order the parts from subaru
Old 05-03-2009, 10:13 AM
Rebuilding
From what I understand these engines rarely mix engine oil and coolant when they have blown head gaskets.
Old 05-03-2009, 10:25 AM
yes, but I have seen it before. It all depends on where the break is in the gasket. Commonly it breaks just outside of the compression ring in the head gasket and leaks compression into the coolant. Other times it can break between oil and coolant jackets and mix the two into eachother or just one into another. Never the less, the gasket is broken or lifted and there is still an issue that requires the repair.
A Headgasket repair is almost all labor. The parts are not terribly expensive but it takes several hours to do it right
Old 05-03-2009, 10:34 AM
evilsvx's Avatar
any price quote for labor since you know what would be a fair price. thank you...
Old 05-03-2009, 11:16 AM
To replace the head gaskets and rebuild the heads without the cost of parts at our shop is an even $1k. That includes resurfacing the heads if need be, lapping all valves, checking vale guide clearances, replacing valve guide seals, and the actual install of the heads and engine
Old 05-04-2009, 10:03 AM
evilsvx's Avatar
so when i replace the headgasket i have to rebuilt the heads too? i thought it was just machine them
Old 05-04-2009, 10:09 AM
It is HIGHLY recommended that the heads be rebuilt, as our cars are all aging and we see MANY cases of worn out valve guide seals. It is highly likely yours are already needing replacement, or will need replacement soon. It would be a shame to spend to have the heads off the motor and the HG done, and then have to do it all over again when you have a guide problem in the near future.
In simple terms, its prudent to have a little preventative maintenance done while the heads are off to avoid future problems, and ensure peace of mind.
Old 05-04-2009, 10:40 AM
It's one of those "let's just do it while we're in here" things. Like replacing the water pump while you're doing a timing belt job.
Old 03-21-2010, 07:15 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
I would like to humbly declare a section of I-80 between Sacramento and Truckee "Oops I blew my head gasket" alley. So far in the last 3 weeks, I have successfully diagnosed 14 blown head gaskets, including 5 subies. While writing them up, I always ask "did ya drive with it in the red for very long?", I overwhelmingly get a sheepish "yeah for about ten minutes after I saw it there.."
I get the long climbing grades from sea level to 7000 feet where we are, and that people often neglect their fluids, but seeing the needle pegged into the red and saying "der dee derrrrr" while continuing to climb Donner summit at 70mph makes me shake my head. Ill just keep filling the vial with the blue fluid, watch it turn yellow, and getting their $89 for my 3 minutes of diag..
Old 03-22-2010, 07:08 PM
kwren's Avatar
kwren kwren is offline
That degree of happiness for $89 in 3 minutes... sounds like a self employed person! Congratz!
Keith
