Old 08-04-2009, 07:05 AM
STeeL25T STeeL25T is offline
Soon to own a fuctional SVX
Send a message via AIM to STeeL25T
Clutch/Flywheel combo
I should have my engine completely torn down by this weekend, so I'm shifting my attention to my neglected busted transmission for the time being. I have an 05 WRX transmission I'm going to repair, right now I'm wondering what kind of clutch and flywheel you would recommend for it. A bunch of people are all about light weight flywheels but I also hear that you kind of want some weight to it for a big car like ours with torque like we have, so not sure which way to go here. Clutches I don't know much about, I ran a stock 300ZX N/A clutch on my turbo 300 hp RB25 and it worked perfectly, but going for 500 hp and AWD I don't think it will be the same haha. I can probably get that info from NASIOC but I guess I'm looking for first hand experience in our cars.
Old 08-04-2009, 08:07 AM
BoxerFanatic's Avatar
Re: Clutch/Flywheel combo
A good flywheel/clutch setup that I have heard of... as I have been looking around for my Legacy GT...
ACT aftermarket clutch disc and pressure plate for 2006-current WRX 5MT.
2006-current Subaru WRX 2.5T flywheel and bolts (stronger, less likely to ream out than 2005-2009 Legacy bolts)
new throw-out bearing, engagement fork, and other misc bits for assembly. (compatible shift fork with whichever clutch slave cylinder you have, push or pull type.)
I've also thought about a stainless braided hydraulic line for the clutch master to slave cylinder, for better feedback, and less hose-flex.
ACT has a streetlite flywheel for that application that is lighter than OE, but if you wanted a more normal-mass flywheel for the EG33, the WRX OE flywheel is probably closer to that.
But I don't have first hand experience. That will probably be the setup I convert my 2005 Legacy to, and get rid of the stock Sachs crap, and the OE dual-mass flywheel that the Legacy came with.
I am not sure what 5MT converted SVXs are running, but am interested to see what gets posted here by folks who do know...
"What you plan, and what actually happens ain't exactly ever been similar..."
1992 Claret SVX. Rescued from certain destruction, and still on the road, where it belongs. Waiting for a bit of a makeover, when I can afford it.
2005 Garnet Red Pearl Legacy GT Limited 5-speed. - The late great Subaru sport touring sedan.
1999 Classic Red Miata, Preferred equipment package 5-speed. Fun, fun, fun, in the Sun, sun, sun.
