Old 06-18-2009, 01:02 PM
Removing rear side panels
the ones below the rear quarter glasses. Anybody have ever removed them successfully without breaking the inner tabs?
If so, HOW?
Thanks
Old 06-18-2009, 06:56 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Re: Removing rear side panels
If you are referring to the inside panel, you need to remove the bottom half of the rear seats. Then remove two plastic screws on the panels (one on the floor and the other on the panel itself (you need to tilt the back of the rear seats forward to see it). Then you carefully pull out the bottom and lift to remove.
Old 06-18-2009, 07:00 PM
redlightningsvx's Avatar
Collision Refinishing Tech
I think he means the rear quarter garnish. I broke almost all the clips and tabs off mine when I painted them so I had to order $30 in clips and use FUSOR 143 plastic epoxy to put them back on. I havn't found an easy way even the factory service manual is usless on this.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 06-19-2009, 12:03 AM
subbieatnz's Avatar
subbieatnz subbieatnz is offline
I broke the clips on my parts car. I think it would be pretty hard to get the clips out
1992 NZDM SVX Maroonish Red/Black ( 1st car ive owned with an cd player ) Has been retired
1989 Vortex 6 Maroon
1983 RX Silver Grey
1973 1400 GSR Yelo 2 Door Coupe awaiting Restoration
Old 06-19-2009, 09:54 AM
I can't understand why the heck did they make these so hard to remove intact?
Guess they were aiming to pull some profit out of selling brand new ones...
Old 06-19-2009, 01:59 PM
SVX SVX is offline
thats a shame.. and it is necessary to remove them in order to gain acess to the the rear speakers right? not looking forward to it..
Old 06-19-2009, 02:47 PM
Hello SVX and welcome to the Network. Give us some detail and information on what car you have, pics if possible.
You are probably misunderstanding the original question; although he neglected to confirm it Danny is actually referring to the removal of the two plastic garnishes that are on the outside of the car, under the glass and forward of the trunk lid.
In the second instance the rear speakers in the SVX are fitted to the rear window shelf. You have to remove the inner panels to get to the rear shelf, but they are not as hard to work on as the exterior trim. You will probably manage to remove them without breaking the 4 clips.
Do you know how to remove the panels? Are you changing the rear speakers?
He means the outside trim with the svx logo by guess. the interior quarter trim is very easy with 2 screws and a good pull.
Seth
Past subies:
Other toys:
Old 06-19-2009, 03:31 PM
Correct
