Oil-soaked front sway bar bushings...
...eventually go "kerplooey," as I discovered on a winding stretch of Tennessee two-lane last night.
Word to the wise: Fix those leaks. My drippy cam cover gaskets were replaced many months ago, but it seems the damage was done. dcb Last edited by dcarrb; 03-29-2007 at 05:38 AM. |
Update 3/29/07
Two weeks+ since ordering, still no bushings. (Mini-rant: Sure would be nice if Subaru would drop-ship directly from parts distribution centers. With computer inventory management, it's absurd that something sitting on a shelf someplace in the lower 48 takes so long to reach a customer.) Before ordering, I phoned the local O'Reilly's to see if maybe they had an aftermarket cross-reference. Nothing in the system. The guy then looked in their new Moog book and chuckled, "they don't even show an SVX." dcb |
Maybe
I was just out playin, looking for components, and I wish I knew the dimensions of the Sway busings without having to pull em. Whataya think. Message at the bottom says 1 and 1/16 inch. I assume Inside Diameter.
The Worm _______________ June '91 Claret LSL #1733, Enkei RS-5's x 16", Original Paint, accompanied by Beautifully speckeled Front Bumper, Sony Audio Components, Small Car Shift Kit, "How to" Hood Lifts {Perfect}, "15 Minute Suspension Mod" Motorsport Floor Mats. Perma-Cool External T. Filter, New Front Axels {1/2008}. "Classic Radiators" unit "$36 coil alternative" and Tranny rebuild at 287k 8/2012 '05 Infinity G35 Coupe. No Mods, 33K Miles |
If you're asking if I think those would fit, I don't know the dimensions. Surely there's something out there that would be an acceptable substitute; the problem would be finding one. A friend kept telling me I just needed to go someplace and sort through their "bin of busings" to luck upon a match. Yeah, good luck finding a parts house that that stores parts that way anymore. I was thinking that I'd read here of aftermarket performance-type bushings for the SVX, but I didn't bother searching because I'd ordered the OEM parts the morning after mine failed and didn't anticipate that it would take so long to get 'em.
A word on trying to find a visual match: The old bushings on my car had swollen to fully 50% larger than original. The rubber was the consistency of a candy gumdrop. When I got the goods last Thursday (one day shy of four weeks) my heart sank because I thought they'd sent the wrong bushings. If you go looking for a replacement, have a mount in hand. dcb |
Check this thread here: HERE, especially the posts by svxfiles.
Also check chike's thread with photos here: HERE Summit Racing has these bushings Energy Suspension Part No. ENS-9-5105G for $13.69 HERE While the car was in the air, I would also consider doing the rear sway arm bushings as well. Direct replacement and fairly easy to do ENS-9-5121G. Click HERE .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 04-09-2007 at 09:54 AM. |
Maybe this is noted in those threads, but it's worth reiterating that the mounting points for the stock clamps are staggered; in other words, the clamps aren't symmetrical, so any sort of alternate clamp would require serious massaging to work. And you'd need to secure appropriate-sized nuts, as the mounting bolts thread directly into the stock clamp.
Not that I'm an old hand at this, but I was surprised by the degree of compression with the OEM bushings. Mighty snug. By comparison, the red bushing pictured in that first thread above sure looks loose. dcb |
Weare not talking about the red bushings, just the two different ones mentioned from Energy Suspension (which are black).
Once the front ones are slightly modified with the notch, they will continue to use the stock bushing clamps and bolts. Believe me they are extremely tight when in place with no looseness. PM svxfiles on this for more information or ask here. he has done many bushing replacements (including mine) using the Energy Suspension products and they work flawlessly! ,
Thanks
Thank You for the input from both sides.
I will start something to remedy this today.
I'm pretty disgusted with the factory parts situation and wish Subaru would enable some provision like drop-shipping for those of us who have no dealership nearby. The sway bar bushings (ordered from Liberty Subaru in NJ) were one thing, but I placed an order with subaruparts.com back over the St. Patrick's Day weekend ('cos they were having a sale) and every item I ordered showed as being in-stock, but when I tracked the package two weeks later, I learned that it took three days just for them to pull and ship the order. That's service for you.
Edit: My mechanic just called. The front wheel bearing and seal set I asked him to order for my silver SVX on Monday? Got it. NAPA. And people wonder why I favor aftermarket parts. dcb Last edited by dcarrb; 04-11-2007 at 01:16 PM. |
*sniff* no one mentioned my group buy
We thought you got carried into the Canadian wilderness by a moose
