Old 03-24-2007, 12:02 PM
kbarrett kbarrett is offline
IAC + throttle body cleaning.
I am having a rough warm idle problem ... I wanted to eliminate possible causes before I replace the ECU.
I have swapped in a working MAF, so that issue is eliminated.
I have cleaned out the TPS, so, should I clean up the throttle body and intake air control?
Or just stay far, far, away from these?
Are there any pics posted of these objects, and a howto?
Old 03-24-2007, 02:16 PM
Manarius's Avatar
Manarius Manarius is offline
Coolant Temperature Sensor?
-Jason
-Obi Wan Kenobi
Old 03-24-2007, 08:09 PM
DarknessofDeath's Avatar
DarknessofDeath DarknessofDeath is offline
Inhabitant of Darkness
i'v'e had rough idle issues ~ when car is warmed up - i was told that it was a bad coil. and then i replaced the engine (head gaskets blew) and more recently i am having rough idle as well...now it's rough idle even when on a cold start..?/ changed out half the ignition coils and i'm looking to do the other half tomorrow (hopefully).
i have no clue anymore at this point. if it's still bad when i change out the other side...i'm going to clean out the throttle body and IAC when it warms up a little more.
out of curiosity. what are symptoms of bad plugs?
i went to take out the ecu before to do the crush mod....and there was no bead to crush
1992 Subaru SVX LS~L Ebony Pearl
1992 Dodge Stealth R/T Firestorm Red
1992 Subaru SVX LS~L Pearl White
1992 Subaru SVX LS~L Ebony Pearl JDM 6MT/DCCD
2007 Subaru Legacy Spec B. Diamond Grey Metallic
Old 03-25-2007, 06:42 AM
billb billb is offline
If you look in my locker, you will find a how-to with photos of cleaning the IAC and throttle body.
Bill
Bill
94 SVX LE 130,000mi
Old 03-25-2007, 08:29 AM
i happen to be looking at your locker a lot for the how to
Old 03-25-2007, 09:16 AM
I'm glad you're looking. I hope you find it useful. Let me know if you have any questions.
Bill
Bill
94 SVX LE 130,000mi
Old 03-30-2007, 09:32 PM
pearlm30's Avatar
pearlm30 pearlm30 is offline
Any update on this issue???
94 Bordeaux Pearl SVX Lsi B&M cooler with Aux ATF filter. QC Kit Plus 06 Sti Gold Wheels. SOLD
92 Claret WRX 5 speed ECUTune 1AV1 Gold STI Wheels & more. SOLD
92 Teal SVX LSL lowered with Konig. SOLD
92 Black SVX LSL with B&M cooler & Aux filter. Small Car Shift Kit. Gone
94 Red SVX L FWDwith LSL Leather Interior. SOLD
92 Teal SVX LSL....with B&M cooler & Aux filter. Small Car Shift Kit. SOLD
95 Polo Green........With Trany Problem. GONE
Almost complete Rear Wheel Bearings Job with Pictures in my locker
My Locker http://www.subaru-svx.net/photos/user.php?pearlm30
Old 04-03-2007, 03:24 PM
I cleaned up the throttle body and IAC .... All the hoses are good, and I added hoseclamps to kill any vacuum leaks.
But I am still getting rough stumbling when warm ... right at 60 MPH ... and now while waiting at the light. The waiting at the light stumbling goes away when I put it in neutral ... I am beginning to suspect a transmission problem.
I opened the IAC a bit more to increase idle RPMs ... the 60 MPH stumble is less noticeable, but the waiting at the light stumble is now worse.
Arrgh.
Old 04-30-2007, 09:34 AM
kis86's Avatar
kis86 kis86 is offline
replacing something or another
Send a message via MSN to kis86
news...
Any update on this...figure it out? I have the same issue
Old 06-11-2007, 04:16 PM
Earthworm's Avatar
Meow!
What about loose intake plenum bolts?
Old 06-11-2007, 05:18 PM
michael's Avatar
michael michael is offline
What Potholes ???
Are you getting any codes?
Wanted: Steering Wheel
