Old 03-11-2007, 08:40 AM
processengr's Avatar
Question How much unequal tire wear between wheels
Hi All,
Daughter hit a curb, took out sidewall on 92. Sears provided brand new Falken 512 tire. BUT, tires had 6k on them, old tire had 1/16" wear (.062") compared to new. Will this burn out tranny/diff?
TIA,
Gordon
Cheers! Gordon
1992 Ebony 251k 444 SOLD
1999 Silver SLK230 134k SOLD
1997 Green Outback 137k SOLD
2013 Honda Accord I4 SOLD
2015 Subaru Crosstrek 30k
2018 Tesla M3 30k
Old 03-11-2007, 09:38 AM
Ken92SVX Ken92SVX is offline
Allowable tire wear
From what I have read, Subaru says that all tires must be within 1/4 inch of each other. With only 1/16 of wear I think it is likely OK. You need to physically measure the outside circumfrence though to see the difference. Measure with the vehicle jacked up or wheel removed, also check the tire pressure, as this will vary the measurement.
Ken
Old 03-11-2007, 12:26 PM
I would say that there would be problems with up to 1/4" wear. I would also measure from the ground to the top of the wheel and make all tires the same. There has been quite a few threads discussing this topic and that is one of the ways to make the rolling diameter the same.
Old 03-11-2007, 07:13 PM
Suby Fan's Avatar
Suby Fan Suby Fan is offline
the standard rule at most tire shops is 2/32-4/32 your fine
- John
Old 03-14-2007, 08:44 AM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Significant Technical Input
Easy way to measure: Mark each tire sidewall directly above the ground (6:00) and roll the car forward until one mark is back at 6:00. Then check the position of the remaining tires.
Give your most difficult job to the laziest person and he'll find the easiest way to do it.
Old 03-14-2007, 09:18 AM
JaySVX's Avatar
JaySVX JaySVX is offline
With the new tire, i would put in the back, the cars are dominantly fwd when awd is not engaged.
*No SVX at the moment...*
1987 Winnebago Elandan 35'
2001 Yamaha Roadstar 1600
Old 03-24-2007, 10:25 PM
greggbzz's Avatar
greggbzz greggbzz is offline
Awitha Cheese-ahhh!
Send a message via AIM to greggbzz
New tires and I hit a giant pot-hole in scranton, all my change fell out.
had to replace the front passenger.
They probably had 4K of wear on them, but it was replaced about 18 months ago and no problems since.
I cringe when I go under that bridge still.
Old 03-24-2007, 10:32 PM
Speedklix's Avatar
Locker Link Solution
Thats what i've been told is safe for em.
Beav, thats a great idea!
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
Old 03-28-2007, 11:17 PM
SVXdc's Avatar
SVXdc SVXdc is offline
Radio wiring harness guru
Originally Posted by greggbzz
... I hit a giant pot-hole in scranton, all my change fell out.
Wow! Did the previous passenger fly out the windshield? Vowed never to ride with you again?
David C.
1996 Laguna Blue Pearl SVX L AWD
See my home page for SVX radio install/removal instructions and wiring harnesses
Old 03-28-2007, 11:21 PM
Hocrest's Avatar
Hocrest Hocrest is offline
Freezepop's are Awesome!!!!
You wouldn't find that hard to believe if you would see the size of some of the potholes in Scranton
Old 04-03-2007, 02:17 PM
sekler sekler is offline
excuse my ignorance guys, but worn tires can really f**k some important parts up ?
Mine are totally shot yet I toughed them all winter..I thought it was more of a security thing than anything else..because of the all wheel drive, I've managed my way around pretty good in the winter here..
so you guys would suggest about changing my tires to preserve the transmission ?
Old 04-03-2007, 03:29 PM
Speedklix's Avatar
...short answer, yes
-Mike
[SIGPIC][/SIGPIC]
