Old 03-23-2007, 01:00 PM
subiedo subiedo is offline
98 Impreza 5 spd? (to swap)
Well still looking for the tranny & parts for a 5 speed swap. I found a 98 Impreza 5 speed in a local yard & wondered if this could be the ticket? If compatible would I want to pull the pedal cage also? How about hydraulic clutch actuators (presuming here it's a hydraulic system) Also think this requires the rear end gear swap out also? Appreciate any input or advice from the Forum on this. Thanks, Subiedo
Old 03-23-2007, 04:53 PM
AFBeefcake's Avatar
Subaru Swapper
You should be able to use the pedal set and the hydraulic clutch actuators as well as the transmission. I don't know on the rear diff, but I think you will need it too.
2005 Legacy GT
My WRX's Cardomain Page
Old 03-23-2007, 04:57 PM
Hocrest's Avatar
Hocrest Hocrest is offline
Freezepop's are Awesome!!!!
To be able to use the rear diff, it needs to have 5 bolts holding in the side plates. I think the Impreza's have screw in side plates? You'll need to source a matching diff from a Legacy.
