Old 02-19-2007, 12:55 PM
Robar Robar is offline
which cam seals to replace w/maintenance?
I am doing major maint. on my 92, and recall reading about cam seals leaking, and replacing them as preventative maint. when you have it torn down for the timing belt etc.
I have seen more than one cam seal listed on some parts lists, and want to know exactly which ones are the typical replacements. Part #'s if possible.
Thanks,
Robar
Old 02-19-2007, 07:15 PM
immortal_suby's Avatar
Thread Killah
806733030 Oil Seal $5.46 (front crank seal)
806732150 Oilseal-32x45x8 $6.11 (cam seal)
I'd replace both while you are in there. You need 2 of the cam seals, 1 of the crank seals.
Locker Link
2015 BRZ Limited 6MT
Old 02-19-2007, 07:38 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Might as well order the "dummy" cover for the other cams. It also seems to weep a bit as the SVX ages and they're only like $3 each.
Old 02-19-2007, 11:02 PM
Speedklix's Avatar
Locker Link Solution
Something I forgot when I was working on my current engine. I think the part number is 807045030. (two of them clearly)
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
Old 02-19-2007, 11:18 PM
Thanks for the info
Thanks - I think I have most of it on the way - need to order a bit more though.
