Old 07-30-2006, 02:19 PM
shotgunslade's Avatar
shotgunslade shotgunslade is offline
Differential Bushing Replacement
Anyone installed Earthworm's Group Buy differential bushings yet? if so, how did you get the old bushings out? We backed off today, fearing damage to the old bushings, with possibility of incomplete removal, and subsequent inability to install the new ones, resulting in a Princeton car stuck in Beach Haven.
____________________________________________
95 LS-i Red, 31,xxx; bone stock for now; Daily Driver
94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; ‘07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light,
2017 Subaru Forester XT, metallic dark gray, 29,xxx
2005 Porsche 911 Turbo S Cabrio, 24,xxx
2006 Subaru Outback LL Bean, 166,xxx sold
92 LSL Dark Teal, Smallcar Shift Kit - sold
Old 07-30-2006, 07:43 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Just watch out for Tom's German Shepard
Seriously...David posted that he had the process worked out (i.e. he's replaced the bushings on his rear diff) and was just looking for time to do the "how to" write up. You might want to PM him directly.
I don't believe there is anyway to remove the stock bushings in one piece....my guess is it's going to take a Sawzall and a lot of patience to avoid damaging the subframe.
-Bill (set of rear diff bushings still sitting in his SVX's trunk...)
Retired NASA Rocket Scientist
Center Network Member #989
Old 08-01-2006, 11:06 AM
Earthworm's Avatar
Meow!
Don't worry about damaging the old bushings when removing. Both the centers pushed out on mine when they were removed. As for the outer ring one was pressed out complete, the other was rusted in place and had to be cut out. We just cut a slit in the ring and "peeled" it out using a screwdriver.
