Old 06-19-2006, 10:08 AM
Crazypolo95 Crazypolo95 is offline
95pologreen
Send a message via AIM to Crazypolo95
Question pSI in tires???
HOw much PSi dose everyone go with on their tire for like a day drive. Cuz i have being putting about 33front and back.? WAs thinking of putting it at like 35 or something so i would not have to think about the psi in the tire for sometime
Old 06-19-2006, 10:51 AM
dcarrb dcarrb is offline
I run about 40 front/36 rear in a stock-sized, all-season touring tire. You should run higher PSI in the fronts; I believe factory spec is 33/29.
dcb
Old 06-19-2006, 11:00 AM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
You are correct. I typically ran pressures close to what you recommended - like 40psi front and 37psi rear.
2006 Steel Gray WRX TR (sold)
Old 06-19-2006, 12:06 PM
SubaSteevo's Avatar
No longer blue member
I usually have about 40/36 as well
-Steve
01' MSM Lexus IS300
Old 06-19-2006, 12:14 PM
95pologreen
I know the stock pSI but i'm not running stock tires or rims. The tires size is 225/45/17. So what so i put in then?
Old 06-19-2006, 12:18 PM
Lee, one of the members here, runs 40psi front and 28psi rear.
The 40f/28r tire pressure he is using is almost the same ratio as the 59f/41r weight distribution of the car, so it makes sense that the front and rear tires should have the same loaded radius when at these pressures.
For much more information than you ever wanted, check this thread for some interesting perspectives on tire pressure ratios:
http://www.subaru-svx.net/forum/show...pressure+ratio
Old 06-19-2006, 12:44 PM
40/36, 38/34, 34/30... just keep the proportions close to stock and don't exceed the tire manufacturer's maximum rating on the sidewall. Generally, softer tires will have a tad more bite and harder tires yield a slightly firmer ride and better fuel economy.
28 seems awfully low to me, even for the rears.
dcb
Old 06-19-2006, 05:20 PM
immortal_suby's Avatar
Thread Killah
I normally run about 47/44 give or take a few psi on my 225/45/17
I get very good even treadwear at that pressure. Ride is a little harsh but I'll take a few bumps in exchange for not blowing a sidewall or bending a rim.
Locker Link
2015 BRZ Limited 6MT
