Old 12-19-2005, 01:58 PM
Hot Foot
Is there anything that can be done to get the heat to stop blowing on the drivers side floor area?
Old 12-19-2005, 02:37 PM
n00b on demand's Avatar
I dont think so...Its supposed to be like that.
Old 12-19-2005, 03:18 PM
So you don't recommend stuffing an old sock into the vent?
Old 12-19-2005, 06:58 PM
You could turn on the AC.
Old 12-19-2005, 07:46 PM
intelisevil's Avatar
<<<Alcyone
or defrost . . .
Dan
Old 12-19-2005, 07:48 PM
Manarius's Avatar
Manarius Manarius is offline
Turn off the heat when you get too warm?
Or, fab up a dual climate control system and turn your side off.
-Jason
-Obi Wan Kenobi
Old 12-20-2005, 04:50 PM
Deflector shields perhaps? Asbestos boots? Seriously, I was just wondering.
Old 12-20-2005, 09:19 PM
ShiuludeSVX's Avatar
ShiuludeSVX ShiuludeSVX is offline
Send a message via ICQ to ShiuludeSVX Send a message via AIM to ShiuludeSVX Send a message via Yahoo to ShiuludeSVX
I believe the flapper stays in the last position used.
If I need it to free run thru the vents, i turn on the vent, and then turn the system off. I get air thru the vents.
If I was using the heat last, then if the system is turned off, it runs thru the floor vents.
Anyone else notice this?
Old 12-20-2005, 09:28 PM
It's Just Eric's Avatar
Missing in action
Mabey mines broken or something, but when the heat is on auto it seems to also come out the vents. Actually, when my heat is on I get a cold air spot right on my right foots toes...seems like its coming from at the top of the gas pedal. Id say its a huge leak or something, but it only does it when the heat is on.
and yeah, I noticed the flapper thing. my caddy did the same thing
R.I.P Cool Signature.
Old 12-23-2005, 03:27 PM
immortal_suby's Avatar
Thread Killah
Yup - that works for me too.
Locker Link
2015 BRZ Limited 6MT
Old 12-26-2005, 11:35 AM
Wocketman Wocketman is offline
I had the same issue...but found that if I click to "off" AND then click "recirc" it shuts off the floor air. But apparently only for a while, every now & then I need to do it again.
Bruce Schwab
Recovering solo ocean racer
www.bruceschwab.com
On land: 92 Ebony SVX, 188k
Old 12-26-2005, 12:58 PM
AppStateSVX's Avatar
AppStateSVX AppStateSVX is offline
Mountaineer
Send a message via AIM to AppStateSVX
Talking
I kind of like the footwamer.......it is especially good after football games when my feet are frozen
1992 Midnight Black LS-L - Sold 3/3/06
1991 Toyota MR2 - Sold 11/27/07
1992 BMW 325i
- Tokicko Suspension
Old 12-26-2005, 01:41 PM
pavanbabut's Avatar
pavanbabut pavanbabut is offline
Send a message via MSN to pavanbabut Send a message via Yahoo to pavanbabut
I will also do the same, but need to know some solution for this.
-Pavan
Old 12-26-2005, 04:48 PM
Use the defroster.
When it gets really cold up here, the heater will actually blow both to the floor and to the windsheild.
I don't use the heater unless it's below 30* so ... iunno.
