Exhaust question, and Shift Kit question help.
On my drivers side, on the exhaust right off the headers there is this resonator/cad-converter/what ever. I am trying to figure out what it is exactly, b/c I thought from searchs that it was a resonator, Midas says it comes up as a converter. If it IS the converter, can I cut them out instead of replacing them? Glasspacks maybe? I don't want to lose any power at all. but I want to fix my exhaust rattle for the cheapest possible.
Also, I installed the shift kit from smallcar this weekend, and was hoping to find the power light blinking problem to stop. It didnt. But it shifts nice and firm. what gives with the blinking power light? |
you can remove the cataletic converter... most of us (with aftermarket exhaust) only use one cat.
as far as your power light... the code is already set so you already have the problem (the shift kit won't magically fix something that's broken). to get rid of the blinking power light you can reset the computer. i usually disconnect my battery overnight to do that. however it may come back if there is actually a problem with your transmission. |
Can you confirm that you are getting error 11 from the TCU?
The shift kit won't help if your OEM resistor is fried.
Resistor
Well I never had a Power light blink before I unplugged the resistor the first time around a month ago. I'll try undoing the battery trick in a couple days.
'92 Liquid Silver SVX - Drilled&Slotted Rotors/Canadian OEM Seat Warmers/JDM Folding Mirrors/JDM Clear Corners/Euro Glass Headlights/Euro Headlight Level Adjustment/Euro Shifter Assembly/ECUTune Chip V.1/GARAGE QUEEN! |
Johnny
Pearl '92 LS-L 179K (Historic 1st 5-speed SVX) Mods: 5-speed, 4.11's, Group-N motor mounts, dual Magnaflows, cone air filter, Kenwood MP-228 CD/Receiver, white-faced gauges, '97 grill, custom window tinting. Ebony Mica '92 LS 80K Oct 2002 - Dec 2004: Victim of theft. She served me well. You can tell the lack of craftsmanship by the wrinkles in the duct tape. |
