Old 05-15-2005, 02:42 PM
michael's Avatar
michael michael is offline
What Potholes ???
Wheel Stud???
Can just one stud be removed without taking them all out? If not does anyone have a 12-1.25 die I can borrow?
Wanted: Steering Wheel
Old 05-15-2005, 05:43 PM
svx_commuter's Avatar
The wheel stud gets pushed out of the hub. The disk has to come off the wheel assembly and then a special tool is used to push the stud out the back. The new stud is pulled into place with a standard lug nut and washers.
I happen to have a broken one right now on the front right. I had my tires balanced a few weeks ago and THEY cross threaded one of the studs. I even aske dthem to use a HAND torque wrench and they said they would.
SuperbVehicleXtraordinary
Proud sponsor of a 1992 SVX.
Old 05-15-2005, 08:23 PM
michael's Avatar
What Potholes ???
I had it all apart a few months ago and could not free the stud. The bolts that hold the abs tone ring in place are rusted badly. From what it looked like all of them had to come out and the tone ring had to be disconnected. I just need to know if you can take one out without removing the whole works. Mine is also the front right wheel. A 12-1.25 die seems pretty hard to come by, I went to a dozen tool places with no luck
Old 05-15-2005, 08:28 PM
SubaSteevo's Avatar
No longer blue member
The tone ring does need to be unbolted. You can get them loose with a BFH, but you can't get them out with the tone ring attached. You also probably need to take the hub off to get the new one in the hole.
-Steve
01' MSM Lexus IS300
