Old 02-18-2004, 07:05 PM
MikeInd
Jdm Earth Ground Wire !!
Does anyone know if these really work the way they say they do?
E-Bay # 2460266315
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2460266315
Old 02-18-2004, 07:24 PM
mbtoloczko's Avatar
sans SVX
Re: Jdm Earth Ground Wire !!
E-Bay # 2460266315
Now there's a debateable question. Some dyno tests done by a few of the tuner magazines have shown a small HP gain when similar wires have been installed on other cars, including a WRX. There's no good theory to explain the HP increase though.
Mychailo
Visit my locker
Old 02-18-2004, 07:26 PM
lee lee is offline
some claim they do, some say it's BS. Use the search button for the "magic three", much the same principle. If your vehicle is stock with no stereo "upgrade", cleaning the ground connections at both ends is probably good enough IMO. Might check the condition of the wires from the alternator. Heat under the hood has baked the insulation on some owners wires and they may become quite brittle.
Old 02-18-2004, 07:54 PM
JLittell
Don't waste your dinero!
Old 02-18-2004, 08:06 PM
Chicane Chicane is offline
Anti-BS Vigilante
Send a message via ICQ to Chicane Send a message via AIM to Chicane
It doesn't look JDM to me. It looks like quasi-asian rice equipment. Make your own.
- Rob
Old 02-19-2004, 05:10 AM
svx1999 svx1999 is offline
- Rob
Maybe because it is 7A.M not only is that funny but Rob is right.
Seen better wires, so save your $$$.
Here is a suggestion. On a 10 y.o car things corrode, you can clean your grounds, reconnect, do the Alt or Stereo upgrade , maybe add something similar to what you found, just NON Quasi-asian and return the Grounds to Factory Spec or Above.
Things will work better!
see, I dunno if it create's HP.. Maybe it all just works better so a difference is noticed and can be repeated , recorded, graphed. There has been many odd ball wiring details found and the Fix given usually includes adding Better wire or New ones. There are so many overlaping pathways in the wiring. I think it makes good sense, restore it to factory spec or above and naturally you get Better performence...
Now I'm going to go run and hide before someone toss's a Dynometer at me.
~svx1999
Old 02-19-2004, 08:57 AM
Mr. Pockets's Avatar
Moderator
I love it...'JDM'...
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
