Old 01-21-2004, 12:28 PM
Mr. Pockets's Avatar
Moderator
My tensioner was working just fine when I replaced my timing belt about two years ago. That sucker was hard to compress.
http://www.subaruparts.com/diag/?mod...ategory=013-A2
Looking at that diagram, replacing the entire tensioner would be expensive. $80 for the tensioner itself and what looks like another $114 just for the pulley.
In terms of things you should replace 'while you're in there,' I'd put the cam seals above the tensioner. I mean, replace it if the pulley's bearing is bad or if the tensioner isn't springy enough. But I wouldn't replace it as part of a normal timing belt change.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
