#31
Forged vises Cast.
Yes the pistons are a pressure casting and the crank and rods are forged steel.
The advantages with forged pistons is there strength at high rpm. The pressure cast pistons are fine for our motor, it is just when the RPMs are up around 7000 to 8000 that forging is best as the cast pistons can crack around the oil ring groove, and at the wrist pin bosses. I think the WRX uses pressure cast pistons also, it is when the sustained RPMs are higher that forging is needed, as in the WRX 22B Sti. Cost is the factor, forged slugs take a lot of machine finishing as the section is thicker and the wrist pin cutaways have to be machined in, instead of cast in. Pressure casting is a lot stronger than gravity cast piston, porosity is not a problem in pressure casting. Harvey.
#32
ok so heres the deal(dilemma), i am purchasing a motor from a yard shortly here. I dont really want to lower the compression, especially if i never go FI, but theoreticlly i wonder much much i have to looser by slightly lowering compression and going with their forged pistons. I hate emiling them so much, is there a mathmatical calcuation or are their too manyother variables?
phil
~Phil Teal 1992 Subaru SVX Turbo - Sold in May 2011 to peace-frog. |
#33
Re: Forged vises Cast.
phil
#34
Re: Re: Forged vises Cast.
#35
#36
Re: Re: Re: Forged vises Cast.
BTW, just for technical accuracy, shot peening helps to prevent cracking not only by removing stress risers due to small surface irregularities, but also by putting the surface layer of the material into elastic compression and by strengthing the surface layer.
#37
#38
#39
Sorry Phil guess your shorthand was too short for me
As for which to go with? You just have to decide what you are gong to do with the engine. Unblown stay with the std pistons and 10:1. Road work blown, you can still use the same pistons, depending on the amount of boost. I have run 14lbs boost on cast pistons at 9.5:1 on the road to 7000 rpm, no problem. I have also blown a hole in a forged piston on the road without a blower. Turbo charging produces little boost at low RPMs so there is not a lot of problems with it. The boost can go up as the rpm goes up. Water injection will hold the top end boost ok to say at 7 lbs. If it is going to be raced, like 10 laps of a circuit using full boost, then use forged pistons and a higher boost say 14lbs plus water and every other device that will keep the combustion temp to a reasonable level. It is the amount of time that it is going to sustain the boost and rpm that needs the lower compression ratio and forged pistons. Harvey.
#40
for what's worth
wolf33h |
#41
Re: for what's worth
#42
Another for what's worth
http://forums.nasioc.com/forums/showthread/t-40339.html wolf33h |
#43
Re: Another for what's worth
