Old 10-14-2003, 09:23 AM
Mr. Pockets's Avatar
Moderator
Tire rotation problem
Isn't it always te simple things that get you in trouble?
As I may have mentioned, I did tire rotations and oil changes on both the SVX and Justy on Sunday. The SVX is probably okay - although I have to admit I haven't driven it. The Justy I drove to work today for the first time this week.
It's drifting to the right pretty severely. All I did was rotate the tires and change the oil - WTF did I DO???
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 10-14-2003, 09:39 AM
svx_commuter's Avatar
Hit a pot hole sometime ago I guess. Time for a wheel alignment. Eh?
SuperbVehicleXtraordinary
Proud sponsor of a 1992 SVX.
Old 10-14-2003, 10:46 AM
Moderator
Well, it's literally like this:
Car drove straight before tire rotation.
Car does not drive straight after tire rotation.
But, you're probably right - the only thing to do is take it to be aligned.
2005 Outback
END OF LINE
Old 10-14-2003, 11:13 AM
Bobb Bobb is offline
Rotation
Hi Nick, Just for fun, put the tires back where they were and see what happens. could be a bad belt on one tire or something not suspension related. Hope its something simple. Take care, BOBB
Old 10-14-2003, 01:00 PM
mbtoloczko's Avatar
sans SVX
It does sound like the alignment is out, and the tires took a set. You should definitely have the alignment checked. Even after the alignment gets reset, the car will still pull until the tires take a new set to the corrected alignment.
Mychailo
Visit my locker
Old 10-14-2003, 04:27 PM
gl1674 gl1674 is offline
First, you can eliminate oil change as a suspect for drifiting problem. It is not
Second, you should check tire pressure and wear patterns on you tires.
A bad tire can pull to a side quite dramatically and its position (front/back) can affect the pull as well.
Old 10-14-2003, 04:57 PM
Moderator
Ha!
The tires are very close in wear left to right. Front to back is a different story. I hadn't rotated these tires in about 15k miles, so the rears looked brand-spanking new. The pressures I have to admit I haven't kept a close eye on.
'It's a Justy - there's not a lot of air in a 12in tire to leak out.'
2005 Outback
END OF LINE
Old 10-14-2003, 06:30 PM
LarryIII LarryIII is offline
You guys missed it all.
He put the SVX tires on one side of the Justy and vice versa.
Larry III & The Beautiful Naviguesser
'19 Tungsten Pearl Outback 3.6R Ltd...."AISHA"
'08 Harvest Gold Outback 3.0L. L. L. Bean...."AIJOU"
'07 Gray Diamond Pearl Outback XT Ltd..."AH SO"
'05 White Pearl & Silver BAJA Turbo..."AH HA"
'97 Bordeaux Pearl SVX LSi..."SUBYDOO"
'94 White Pearl SVX LSi..."PEARLY"
'92 White Pearl SVX LSL w/touring pkg..."SVXY"
'92 Teal SVX LSL w/touring pkg..."ALCYONE"
'96 Polo Green LSi ... "MIDORI"
'00 Black Dodge VIPER RT-10... "VINNIE"
Engineers do it with precision.
English teachers are novel lovers.
Home: larrysingeriii@comcast.net
SVX FEVER, CATCH IT AT A MEET NEAR YOU !!
Old 10-14-2003, 08:48 PM
Ron Mummert Ron Mummert is offline
Invisible avatar
Send a message via AIM to Ron Mummert Send a message via Yahoo to Ron Mummert
Wink
Obvious. You should have changed the tires, & rotated the oil.
Anytime.
Ron.
(Didja' hear about the absent minded park policeman? Yup - mounted his whistle & blew his horse).
Good s**t happened. 69 was worth the wait.
'92 stock semi-pristine ebony - 160K
'96 Grand Caravan - 240K
'01 Miata SE - 79K
'07 Chrysler Pacifica - 60k - future money pit.
Old 10-15-2003, 05:10 AM
I use a shop with a Hunter alignment machine. It does the alignment even if the tires are worn. What a nice concept. (Beav recommended)
Old 10-24-2003, 05:00 PM
Earthworm's Avatar
Meow!
Our Justy has well over 185,000 miles on it and I don't remember EVER getting an alignment on it. I'm sure it tracks pretty bad but has never really had poorly worn tires.
(SVX is another story)
Display Modes
