Old 08-01-2003, 12:21 PM
4cfSVX 4cfSVX is offline
Unhappy Broken CD Player
CD goes in fine, starts to spin, and then ejects. Laser lens cleaner no help. Any suggestions? I'm also thinking about a replacement. Does anyone know what type of connection to the radio is required?
Any input is greatly appreciated. Need to hear my music!
Old 08-01-2003, 12:54 PM
Wire Harness
A member here sells wire harnesses that will adapt other stereos to the car. Try this link.
http://www.subaru-svx.net/forum/show...t=wire+harness
Old 08-01-2003, 01:04 PM
JLittell
You can call this guy. He's pretty good with repairing stock stereos/ CD players. He fixed my display lights in mine at a very reasonalbe price!:
http://www.carstereohelp.com/subaru.htm
Old 08-02-2003, 04:45 AM
MartyMcFly MartyMcFly is offline
Unhappy Stock CD-Changer!
Hi 4cfSVX!
I had the same problem one year ago.
The mechanic told me that it would cost too much to repair it (he didn't even find the real problem), so I bought a new one.
Hope someone can fix it for you, cause I still have my old stereo and maybe I can also repair it then.
Good luck
mfg hrc
Ænima
Old 08-02-2003, 07:15 AM
immortal_suby's Avatar
Thread Killah
If you're handy with a soldering iron I hear that a few members have taken apart the radio and fixed the broken solders that are causing the problem you have.
Locker Link
2015 BRZ Limited 6MT
Old 08-02-2003, 10:37 AM
Thanks for the info. I'm going to take it apart. Looks like the laser is out of position because I can see the marks it is leaving on cd.
Haven't been able to find a replacement for just the CD Player - can't find anything that will work with the radio. If I can't fix it or get a used one, I'll replace both.
Need a cassette player, so I' thinking about Pioneer KEH P2030 cassette receiver (XM ready) and CDS-P4000 cd player. Ordered the wiring harness from David, if I go thi way. Anybody familiar with the Pioneer?
Old 08-20-2003, 12:11 PM
cherokee 18 cherokee 18 is offline
CD Repair possibility
I experienced same symptoms, removed unit, removed top and lower covers- the disc pressure plate had disengaged from mechanism that positions CD. It's about one inch in Diameter, has 3 spring clips and can be replaced without too much effort. Now I never leave a CD in my player if the cover is closed so I don't have to do this trick anymore. Good luck
Herb
Old 08-20-2003, 01:13 PM
I'll give it a try. Thanks
Old 08-20-2003, 01:24 PM
JLittell
Mine did the same thing. I sent it in to Panasonic for $200 to have it fixed (now under warranty!). I should have replaced it w/ a aftermarket stereo. BTW, Does everyones CD sometimes skip or not read tracks when the inside of the car is hot? Mine does.
Old 08-20-2003, 06:14 PM
Paxton71
skip when hot
Mine was more prone to skip when hot too.
After a serious lens cleaning effort, the formerly unusable CD player works well. It used to skip on all bumps. Even a good throttle mash would make it skip. It turned out to be just dirty. Try one of those cleaning disks, John...It's a cheap effort with little to lose.
