Old 08-07-2003, 11:38 AM
Phast SVX's Avatar
Phast SVX Phast SVX is offline
BOOOOOOOOOOOOOOOOOST
Send a message via AIM to Phast SVX
Asking for a favor
I was wondering if anyone has the daigram for the throttle body intake manifold rememoval. I figure i might as well take the whole thing off and replace the pcv valve while i clean out the entire intake tract. If anyone has any diagrams(and advice) it would be incredibly helpfull,Thanks alot in advance!
phil
~Phil
Teal 1992 Subaru SVX Turbo - Sold in May 2011 to peace-frog.
Old 08-07-2003, 12:59 PM
wawazat??'s Avatar
Yeah, I'm still around
Not a bad job Phil
Just time consuming. I don't have diagrams, but it's really not that difficult. Depending on where you split the intake from the heads will depend on which gaskets you will need to replace. I chose to leave the injector rails in position on the lower stubs and just remove the upper half. Remove the throttle body (mark the throttle cable and cruise control cable before you remove the locking nuts. Remove the 6 or 7 bolts holding it to the manifold and remove it. Remove the vacuum lines (probably a good idea to replace them, they'll all be brittle and will break when you bend them), and unclip the fuel lines and electrical connections. Pull the upper manifold and flip it over to access the PCV. It wouyld be a good time to really clean the throttle body front and back and into the intake cavity as well. Add new gaskets, reconnect everything you previously removed, and torque bolts to taste
Take a look at the parts diagram at the subaruparts website for some exploded views.
http://www.subaruparts.com/diag/?mod...ategory=050-A2
Have fun in your garage (Griot's Garae tag line, but I like it!)
Todd
Down to none
Old 08-07-2003, 01:03 PM
svxqueen svxqueen is offline
Send a message via Yahoo to svxqueen
I think there is something in the How-To on how to remove the intake manifold
Amanda
Old 08-07-2003, 01:11 PM
Phast SVX's Avatar
Re: Not a bad job Phil
Todd
Thanks alot todd, and dont worry i will(for the first few hours of it atleast )
phil
~Phil
Old 08-07-2003, 04:58 PM
immortal_suby's Avatar
Thread Killah
Not a bad job at all. The hardest part is getting all the vacuum lines back on when you put the manifold back in place. Makes it real easy to get to the pcv and also the knock sensors. Definitely need to have some carb and choke cleaner on hand to spray out the intake runners with.
Locker Link
2015 BRZ Limited 6MT
