Old 05-03-2003, 11:16 AM
elninoalex's Avatar
elninoalex elninoalex is offline
Registered Abuser
Pre Cats
Are they necessary to pass DEQ? The 5 spd crossmembers are basically sitting on the pre cats, so I have to act soon. I am planning on cutting the front pipes just downstream of the o2 sensor ports and removing the two cats and putting in a straight 2" pipe on both sides. That would certainly solve my clearance problems. And I would be retaining my center cat, or at least a high flow version of it. What's are the pros and cons of this? Other than legality of course. Thanks.
Stephen
92 Ebony - Level 10/n2o REAR-ENDED
92 Teal - painted yellow/4.11 5spd/n2o SOLD
92 Claret - 4.44 SOLD
94 Barcelona - FWD SOLD
92 Ebony - 3.90 SOLD
94 Laguna ROLLING w/4.44s/Ecutune ECU +TCU/STI springs/Infiniti M45 rims
Old 05-03-2003, 01:13 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Significant Technical Input
Most replacement (non OE) cats replace both pre- and main cats in a system. Check with your supplier regarding the specific model you plan on using.
Old 05-03-2003, 03:56 PM
elninoalex's Avatar
Registered Abuser
Actually, I am going to use a universal hi-flo dual 2" in and single 2.5" out for the center cat. And straight pipes up to the headers.
