Old 04-14-2003, 08:13 AM
Joe C.
Question front-end rumble/vibration
Hello svxers,My 96l,43K has gradually developed a "rumble/vibration" in the front-end.It happens when starting from a dead stop to 5-10 mph.It seems worse when turing the wheel either way.Am also noticing it occurs briefly when trany shifts into higher gears.Any help would be greatly appreciated!
Old 04-14-2003, 08:39 AM
svx_commuter's Avatar
My car has been doing that for sometime now. I am going to going to the alignment checked. I looked at everything else, tie rods, Bj's, bushings and nothing seems to be loose or worn out inthe front end. I let you know when I know.
Old 04-14-2003, 06:09 PM
I just got the alignment checked and it was not that bad. The toe was a little out and not in. The noise I get is from the tires on the back. The inside edges of the tires is not round. It has a wash board apearance. I had these tires on the front for too long and this is how they wore. Ran too a low a pressure also and took too many corners too fast. Not a good thing to do to Yoko AVS db's. I should have rotated them more often. Nothing is loose and all the bearings feel okay.
I actually post a similar question back in the fall and the response was..."Look at your tires" I should have listened.
Old 04-15-2003, 12:25 AM
DavieGravy DavieGravy is offline
I've had this same problem and put it down to tires.
Out for good.
