Old 06-17-2006, 03:15 PM
GreenMarine's Avatar
From POST-***** to LURKER
WTB : Powersteering Pump and Tensioner Pully
Howdy all... I have been chewing up belts left and right lately... I have come to the conclusion that it is either the Tensioner or the Powersteering pump that is causing me these issues... So in an effort to erase all doubt, I am just going to replace both....
Does anyone have a New (or close to new) Powersteering pump and the belt tensioner (on the same belt as the PS Pump....)... Please PM me if you have either, or both of these...
Thanks
Old 06-18-2006, 11:15 AM
Chris,
I have a power steering pump off a 95 L you can have for $40 if you want it....but I used the belt tensioner on FrankenWedge...
Old 06-19-2006, 11:27 AM
Have you tried spinning the pulleys yet to see if any of the bearings are shot?
Old 06-19-2006, 02:24 PM
I took the belt off a while ago and tried spinning them... Couldn't tell what was "Normal" and what wasn't... That is why I just want to replace everything and eliminate the variables.... I simply don't have time to "eff" with the car while I am in school and these little things are really starting to piss me off... I'm just gonna start replacing everything that isn't in top notch operating order....
Old 06-19-2006, 02:27 PM
Originally Posted by huck369
Chris,
Cool Huck.. I'll definitly let ya know... I don't have the internet at my apartment at the moment but should be back online by the end of the week.. I'm gonna try to find a tensioner and do everything at the same time...
Old 06-19-2006, 04:44 PM
Normal = quiet.
I'd hate to find that after all that the problem remains. It could be that the belt is slipping on your crank pulley.
Old 06-19-2006, 06:45 PM
Slipping on the crank pully??... Didn't think that was possible...
Old 06-19-2006, 07:35 PM
It's possiable....the crank pulley could be seperating, as it's a fairly common problem as they get older, the rubber isolation ring in the pulley fails, allowing the inner section to turn while the outer section slips....
Old 06-19-2006, 08:26 PM
Speedklix's Avatar
Locker Link Solution
Yup, infact it is hard to tell it is until it starts diggin into your belt cover . Maybe a rubber strap wrench around it would help you see if it is turning. The outer pulley should turn before the the inner can turn the crank. Mine did. I'd still check the idler pulley while the center bolt is tightened.
If you are having a hard time hearing touch a screw driver to the bolt, and put your ear on the handle. You'll know if it is bad. If memory serves correct, you can't do this to the ps. But maybe try it on the res anyway.
Not trying to talk you out of just replacing em, but like EW, I'd hate to see you waste the $$.
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
Old 06-20-2006, 10:11 AM
I can guarantee you his crank pulley is NOT separating
Old 06-20-2006, 10:45 AM
Speedklix's Avatar
"Perrin Lightweight Crank Pully (1.2lbs)"
-Mike
[SIGPIC][/SIGPIC]
Old 06-20-2006, 11:22 AM
I guess I should read the mods before I reply huh?.....
so the pulley is NOT the problem...
Old 06-21-2006, 02:24 PM
Hahaha .... Yep, My crank pully should not have a problem of seperating
Old 06-29-2006, 01:53 PM
SOmething that I noticed today.... The belt seems to get looser slightly everynow and then.... I can tighten it and it will be fine... then about a week later (depending on the amount of driving I do) it is back to squealing again....
Thoughts??
This would lead most to believe that it is the tensioner right??
Old 06-29-2006, 02:41 PM
When you adjust the tensioner are you tightening the locking nut on the tensioner pulley after adjusting?
