miscellaaneous svx
i have two very important questions today.
1. what should i do about the belly pan bolts that keep breaking off? 2. when i look from the front underside towards the rear, with the belly pan removed, should i see a toothed fly wheel-like part ( i know this is an auto trans, but...) Shouldn't there be some kind of cover over this flywheel-like thing? I appreciate any and all repsonses... |
Re: miscellaaneous svx
You're a better man than I am. So far I haven't even lifted up my car.. Which I will have to do this weekend to get the wheels going the right directions! I do have a question though, what are you doing to break off the bolts. Are the roads that bad up in Park City that you're bottoming out?
Mitch Hansen
"uncamitzi" This is a Dark Ride 92 Teal SVX LS-L 128K tranny swap with 4.11's Well.. my days of not taking you seriously have certainly come to a middle . |
2. You are seeing the driveplate. The starter motor meshes with those teeth, just like on a flywheel. I don't remember if the underside is supposed to have a cover over the access hole, but the cover that fits in the upper hole basically sits there without any kind of catch or tab. I don't know why mine is still there. Those access holes are the only way to get to the bolts that attach the driveplate to the torque converter, so, yeah, there's supposed to be a hole there.
Re: Re: miscellaaneous svx
but no, the bolts don't break off, they freeze up. and come to tink of it, i bottom out in salt lake city more than park city because of all those concrete run-off ditches!!! |
you're right
You do have to drive pretty careful around here the curbs and runoff ditches... I think I might miss the Pac Hyway.... But I am glad to be back where I will get to test the awd (if it ever snows)....
Mitch Hansen
