SVXBot
Old 01-11-2018, 02:47 PM
elemgee elemgee is offline
Tachometer RPM's Reading Low
My 94's tachometer recently started reading low RPM's. At idle, for instance, it reads around 300 rpms. When accelerating, the highest it will read is around 1,400 rpms. The engine runs and sounds fine.
Thought it might be due to the very cold weather we're having here in the northeast but its around 60 degrees today and the problem persists,
Any ideas?
Thanks.
Larry
Old 01-11-2018, 03:45 PM
oab_au oab_au is offline
Re: Tachometer RPM's Reading Low
Any ideas?
Thanks.
Larry
Hi Larry, the taco gets it's signal off the ECU, so does all the other units, engine, gearbox, etc, so that should be OK.
It does have a separate ground up behind the dash, or it is seizing up.
One Arm Bloke.
Tell it like it is!
Old 01-12-2018, 07:44 AM
gwynethh's Avatar
gwynethh gwynethh is offline
Mine is doing the same a bit intermittently. I have a replacement unit ready for install during car work season (July1 to Aug 30 here in New England). Here is a proof of issue video. https://www.youtube.com/watch?v=JMQ1apL_uC4. Keep us informed of your solution.
"Peace is the flower of justice."
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
2001-2015 SVX World Network
