Headlamp care
I just had my headlamps cleaned of the cataracts. Any suggestions to help preserve my newly gained cleanliness and visibility?
Randy \()-()/ ii |
Yeah, don't use your headlights....ever!
Well keeping it out of the sun is probably the best thing you can do. The less heat the better.
I think driving with a blue car cover on would help - they say blue cuts out some of the Sun's damaging rays - just cut holes in it for the windshield like a "ghost" on halloween.
edit Seriously, look here (near bottom of page) http://www.subaruparts.com/catalog/?section=176 Last edited by lee; 09-05-2002 at 08:13 PM. |
The third suggestion I can take. The first two..uh...hmmm..i dunno
Thanks Randy ii |
Along these lines, HOW did you clean them or have em cleaned? Mine are all yellowed and I want to clean them before I get my HID upgrade.
-mike |
Good luck. Randy ii |
http://www.svxworldnetwork.org/ Then click on howto, then cleaning your headlight. I have more to upload there. I am just real busy
Lwin M. Maung (Member # 147) Current SVX: NONE Previous SVXes: 1994 LE Barcelona Red 107k 1992 LS-L Pearl White 143k 1994 LSi Bordeaux Pearl 220k 1992 LS-L Ebony Pearl 184k 1992 LS-L Liquid Silver 145k 1992 LS-L Liquid Silver 102k 1992 LS-L Ebony Pearl 123k Other current cars:2001 Jeep Grand Cherokee Black If at first you don't succeed, CHEAT!
Another product that has been used with great success is Eagle brand small scratch remover. It does an incredable job using it on a rag and after a very short time they are completly clean and no yellow remains. You might try it first. I have used it and it works wonders.
Here is the link to where it can be purchased. Good luck. http://www.eagleone.com/products/pro...02&itemid=1056
. Earl .... ... .... ><SVX(*> Subaru Ambassador [COLOR=silver]1992 Tri Color L[/COLOR] ~45K (06/91) #2430 1992 Dark Teal LS-L ~184K (05/91) #0739 1992 Claret LS-L ~196K (05/91) #0831 1992 Pearl LS-L ~103K (06/91) #1680 1992 Pearl LS-L ~151K (06/91) #2229 1992 Dark Teal LS ~150K (07/91) #3098 (parts car) 1992 White LS-L ~139K (08/92) #6913 1993 25th AE ~98K (02/93) #164 1993 25th AE ~58K (02/93) #176 1993 25th AE ~107K (02/93) #215 1993 25th AE ~162K (02/93) #223 1994 Laguna Blue Pearl LSi ~124K (1/94) #2408 1994 Laguna Blue Pearl LSi ~144K (10/93) #1484 1994 Laguna Blue Pearl LSi ~68K (10/93) #1525 1994 Barcelona Red LSi ~46K (02/94) #2624 1994 Pearl LSi ~41K (12/93) #1961 1995 Bordeaux Pearl LSi ~70K (02/95) #855 1996 Polo Green LSi ~95K (03/96) #872 1997 Bordeaux Pearl LSi ~55K (08/96) #097 2003 Brilliant Red LS1 Convertible ~29K (04/03) #8951 1999 Magnetic Red LS1 Coupe ~33K (04/99) #6420 My Email | Old Locker | New Locker | Picture of 15 of the 19 |
Chrome polish also works great. A bit more bit in it.
- Ca$h |
I use the Novus 3-stage procedure. I think most can attest to its effectiveness.
The #3 is a deep scratch remover #2 is a fine scratch remover, and #1 is a clean and shine protectant. First clean the lens with the clean and shine, then, using lots o' #3 and some elbow grease, clean the lens in a circular motion, rubbing hard and making sure the surface is always "wet" with the medium. Let it dry to a haze, then, buff it off with a clean terry rag. Do the same with the #2 product. Then, spray on the clean and shine, wipe throroughly, then buff with a clean cloth. You'll be amazed at the results. You can also do the above with a power buffer if you're so inclined. All three of the compounds are available at http://www.jcwhitney.com Just do a search on Novus -- it's available in the 3-piece kit for around 15 bucks. Since it's forumulated for plastic, it's safer to use than, say, chrome polish or rubbing compounds, which are initially effective, but potentially harmful.
He said something LIKE blackout. You don't have to be a dick about it. I'm assuming he means some sort of clear protectant spray, similar to black out stuff only clear.
- Ca$h |
