Old 08-16-2002, 08:16 AM
removing radiator
Iam going to be removing the radiator soon, I was wondering if any of you guys could give me some tips on removing, (exactly how to) and things like that. Thanks in advance, chris
Old 08-16-2002, 12:10 PM
Ovidiu STAN Ovidiu STAN is offline
No tips. Maybe just - remove the fans first.
It is obvious once you start.
Just remove it!
Old 08-19-2002, 11:41 AM
svx_commuter's Avatar
I drive the car up on 6" blocks so that the Tranny fluid does not drain. Disconnect the hose to the over flow bottle. Drain the raditor by removing the bottom hose at the radiator. The fans can stay attached to the radiator just disconnect the wire connectors. Plug the trans hoses so nothing gets in. Do not leave the coolant system drained down for long if possible. Used distilled water when you fill it up with coolant. No solids in distilled water.
You mat want some new tranny hose and clamps before you start and coolant hoses and clamps.
Old 08-19-2002, 10:48 PM
Green1995SVX
Chris let me know when you're gonna do this... I'll come help.
-Mike
Old 08-20-2002, 12:55 PM
hey guys thanks for the tips, mike I'll let you know when Iam going to start this, I have to wait to hear back from rallispec, then I'll let you know. later
chris
Old 08-21-2002, 12:36 PM
elninoalex's Avatar
elninoalex elninoalex is offline
Registered Abuser
Undo the fan wiring
disconnect the top and bottom hoses
remove the 4 little bolts at the top(2 on each side)
slide radiator up and out of car
takes about 5 minutes
92 Ebony - Level 10/n2o REAR-ENDED
92 Teal - painted yellow/4.11 5spd/n2o SOLD
92 Claret - 4.44 SOLD
94 Barcelona - FWD SOLD
92 Ebony - 3.90 SOLD
94 Laguna ROLLING w/4.44s/Ecutune ECU +TCU/STI springs/Infiniti M45 rims
