Old 05-11-2017, 03:08 PM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
Heated electric swivel side mirrors
Hi guys,
just looking at the possiblity of retro-fitting electric heated wing mirrors.
In New Zealand we only got electric (glass only moving, with manual push body type) and I would like to go the whole way and fit what some others got.
I have got the following -
mirrors, just have to swap over outer colours.
mirror timer, but no mating connector - so I have reverse engineered the circuit.
thermistor controller, don't think I can get into this unit, hence need more info.
Mirror heated switch
In/Out position switch (similar to normal mirror adjustable switch) - but extra fuction.
What I need is a circuit diagram from a CXW version of the car (unsure if this is an S3/S4) showing connector pin numbers and locations etc
Now I presume that the timer/thermistor unit fits under the glove-box.
File Type: jpg kirabo831-img600x450-1481202863euwmpf1872.jpg (24.2 KB, 195 views)
File Type: jpg kirabo831-img600x450-1481202863ibtw1s1872.jpg (28.3 KB, 186 views)
File Type: jpg kirabo831-img600x450-1481202863snmefs1872.jpg (43.1 KB, 191 views)
Old 05-12-2017, 06:06 AM
gwynethh's Avatar
gwynethh gwynethh is offline
Re: Heated electric swivel side mirrors
If you are not determined to make it factory, there is a mirror power folding circuit on you tube. Works automatically when turning the car on or off.
https://www.youtube.com/watch?v=C0Q02pww3kw (this is the one we used).
https://www.youtube.com/watch?v=GygSmBjZsD8 (this is interesting).
"Peace is the flower of justice."
Old 05-12-2017, 05:18 PM
SURTEESS's Avatar
I know how to wire-up for folding option, what I require is the info for the heated option, I presume it goes to the thermister circuit block ? but how to connect it up?.
Old 05-13-2017, 04:14 PM
gwynethh's Avatar
Opps sorry.
Old 03-28-2019, 03:31 PM
SURTEESS's Avatar
ALSO
I would like to swap the glass out on one of the mirrors (it has slight salt/water damage) - does anyone know how to remove the glass from the swivel (U/D/L/R) joint ?.
Old 03-30-2019, 11:17 AM
theflystyle's Avatar
Originally Posted by SURTEESS View Post
ALSO
I followed the steps in this thread to replace my stock mirrors with the blue tinted convex ones. Not sure how much they will help you as they are for a newer Legacy, but it may be good base reading material
https://legacygt.com/forums/showthre...or-195813.html
1994 SVX LSi
2008 Legacy 3.0R
