Old 11-28-2011, 02:47 PM
Gamesy's Avatar
Gamesy Gamesy is offline
all interior lights dont work
my clock/maplights/domelight/gaugecluster/climat control unit lights all stopped working
what would cause that
Old 11-28-2011, 04:53 PM
Re: all interior lights dont work
Most obvious is check the fuse .Both locations
Old 11-28-2011, 10:27 PM
Gamesy's Avatar
did that all fuse fine unles there' a 3rd location,
even the power to the deck cut out
Old 11-28-2011, 11:33 PM
Door lock timer possibly.
Does the car still start and run?
Old 11-29-2011, 10:14 AM
Gamesy's Avatar
there's a door lock timer?
ye car still runs and outer lights still work
Old 11-29-2011, 11:54 AM
Wikedjuggalo's Avatar
Rebuilding
Check the lighter socket fuse.
Old 11-29-2011, 01:16 PM
Gamesy's Avatar
not that, its still working
Old 11-29-2011, 03:54 PM
Rebuilding
I'd go through all the fuses pulling them one by one. If the fuse isn't blow then you have a bigger problem
Old 11-29-2011, 04:28 PM
It might be worthwhile to check out the wiring to the sun visors. Many odd problems such as these have been a result of broken or frayed wires.
Do a search starting HERE
Old 11-29-2011, 11:43 PM
Gamesy's Avatar
that HERE does nothing svxess
btw chalk up rear defroster to that list of stuff that doesnt work
Old 11-30-2011, 12:35 AM
Rebuilding
Did you go through each fuse?
Old 11-30-2011, 06:42 AM
LetItSnow's Avatar
Still Cant' Say the Z-Word
^^ That seems wasteful. Apologies.
If the lighter works, the visor lamps shouldn't be used as a diagnosis for this problem; they're unrelated this far down the line.
Does your rear wiper work? If not, I'd be with Nate on the time control unit. Believe it - your interior lights, rear defroster, and rear wiper are all tied into it.
Old 11-30-2011, 08:34 AM
Sorry about the link. I just typed sun visor wires into the regular search box and got a listing of various electrical scenarios.
Old 11-30-2011, 08:43 AM
redlightningsvx's Avatar
Collision Refinishing Tech
sounds like what mine did a while ago. Turned out it was a bad time control unit. its located behind the glovebox.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 11-30-2011, 11:50 AM
Gamesy's Avatar
rear wiper works but not the intermittent function
that could explain the burning electrical smell that came through when i turned the vents on....
does anyone have a pic of what it looks like and/or have an extra part?
