all interior lights dont work
my clock/maplights/domelight/gaugecluster/climat control unit lights all stopped working
what would cause that
Re: all interior lights dont work
Most obvious is check the fuse .Both locations
did that all fuse fine unles there' a 3rd location,
even the power to the deck cut out
Door lock timer possibly.
Does the car still start and run? |
there's a door lock timer?
ye car still runs and outer lights still work
Check the lighter socket fuse.
I'd go through all the fuses pulling them one by one. If the fuse isn't blow then you have a bigger problem
It might be worthwhile to check out the wiring to the sun visors. Many odd problems such as these have been a result of broken or frayed wires.
Do a search starting HERE .
btw chalk up rear defroster to that list of stuff that doesnt work
