no power light
i have a 96 svx, when i baught it a few months ago i didnt knwo much about it, well i was told recently there is suppost to be a power light that comes on, well my power light wont come on and i already replaced the bulb and cleaned the connections, whats some other things i could try?? also it shifts at 4500 rpm at WOT, so i guess power mode isnt working??
If you mash the gas from a stop, it doesn't come on? Hm.
I'd say the fact that it's shifting at 4500 at WOT is your real problem, not power mode. Figure out why it's doing that first, and most likely you'll get power mode as a result of fixing that problem. |
i see what your saying but it doesnt even turn on when i turn the key to on or even start it up... i had to get a new ecu because a previous owner either let it sit for a really long time or he switched the terminals on the battery, thats what a shop told me after they put a new ecu in, could it be the tcu is also needing to be replaced??
might be the wrong TCU
2007 GS 450h-Active Stabilizer/Radar cruise 1994 L Blue 3.70 VTD ASE Master Automobile ASE Advanced Level Specialist Toyota Master Diagnostic Technician (former life) |
a tcu maby not for the svx? but maby for a diffrent subaru u meen?
Uh, if the light isn't coming on on startup then I suspect the TCU is wrong/faulty, as has been said... it comes on on startup as an indicator that the TCU is functioning properly, just like the Check Engine light does for the ECU.
would it be worth a shot to disconnect the connections and use some cleaner on them??
ok heres some good news i guess, heres what i did: i took the prongs on the TCU and sanded them, blew out the connections that pulg into the TCU, my battery was disconnected for over an hour, so when i connected everything back i let the car idle for a straight 10 min. without touching anything, well i went to go for a "spin" and the power light didnt come on so i said what the hell, i was in a moderate traffic doing 40, punched it and o wow!!!!! i was gone!!!! it went to 45000 rpm and all of a sudden the G'S started to pull me back and it shifted at 6400rpm, did it a few more times because it was so much fun , bad news= still have that dang hesitation at mid accelration...
-Bill
i have a 96 ecu, but its a diffrent type of hesitation, sounds like im running on 2 cyl's, its really embarrising.....
Is it the strange hesitation around 3k RPMs? My car had that too. You'd floor it, the car would rev up... then hit 3k and pause... then continue revving. Shift and repeat.
I fixed this problem by installing the ECUtune Stage 1v5 chip. |
nope its not actullay a hesitation but a series of backfiring and bogging.... u floor it and it just completly goes wack.... even mild or easy accel. and itll do it
