Need help...I have a miss!!!
Actually, it is my son's car. 1994 FWD with about 60,000 miles. Car developed a miss, so, we pulled plugs, and found the rear plug on passenger side was the problem. Carbon deposits and, obviously, not firing.
First thought was coil. Replaced the coil, and still have the issue. I confirmed it was that cylinder by unplugging that injector, and observed no change. Any ideas?? I need to get this figured out, he is itching to get a truck, so this car may be for sale, and don't want to sell it as it is. Thanks, in advance, for any help. kevlars |
Re: Need help...I have a miss!!!
You did change the plug, right? Try swapping injectors.
Has the timing belt ever been changed? You could remove a cover and confirm it hasn't skipped a tooth or two. Beyond that it could be a valve issue but highly unlikely with so little mileage. |
Spark plugs have all been changed. I don't know about timing belt. But, wouldn't that cause an issue with more than one cylinder? If I change the injector, what is the best way to tell which cylinder is not firing, short of seeing it on the plug? I'd rather not pull the plugs if I don't have too.
Thanks for the help! |
Oh, DUH!! I actually found this one by looking at the plugs, which needed changing anyway. I will try that. Thanks!! kevlars |
Never removed an injector. What do I need to know? I don't want to mess one up removing it.
kevlars |
Sorry, I can't help you there. I've only removed them on a GMC truck and that was many moons ago.
If you are desperate remove the whole rail and sent all three to Mr Injector for cleaning and testing. http://www.mrinjector.us/ We did that on a spare set of rails and got great service. Not cheap/not horrible. Well worth it. He also has a video on removing SVX type injectors but if memory serves, he does it with the rail removed. Have you check YouTube for videos of people who have removed injectors?
"Peace is the flower of justice." |
Let me join in on the "help I have a miss" party...
I've got a miss in the #5 cylinder, according to the OBDII code reader at AutoZone. I was thinking coil pack too, but it clears right up after the car warms up. The car is also getting increasingly hard to start - I'm not sure if that's related but I thought I'd throw it out there and see if it rings any bells. It's got a brand new battery (like a month old), and that seems to have ~12V (11.96 or so), but when I crank it it just goes, "R-R-R---R--R-R-R----R-R-R-R" and then will finally catch and I have to give it a bunch of light revs to keep it going. Meanwhile the whole car is shaking. Once it warms up though, it's good to go. I can drive it to work. turn it off, re-start it (again with the struggling bit) and it'll run just fine. So, to summarize: runs REALLY rough until it warms up and then is just fine. Also really really really struggles to start. (This car is becoming a money pit!)
Austin __________ '97 LSi Ebony - daily driver - mostly just needs body work [couple o' rust holes, door dings, and peeling clear (of course)] '96 LSi, Laguna Blue (retired - soon going to a new home) '89 XT6 5 speed (Gone but not forgotten) Last edited by Austin; 06-07-2016 at 11:33 AM. |
http://www.subaru-svx.net/forum/show...fuel+injectors
Spray a bit of WD40 or Kroil at insert site after cap/connector removal and let it penetrate over night. Grab the injector with a rag for grip and fairly gently twist it while pulling upwards. Should pop free. Above link gives source for replacement pintle caps which are on the bottom of the injector and often need replacing..pretty cheap so even if yours are intact, better to replace. Similarly new O ring sets available on eBay, AutoZone, et. al. I use silicon spray to lube them up for insertion since I think engine oil can deteriorate the rubber..one injector site rebuilder says engine oil is fine though. |
Oddly enough my hard starting seems to have cleared up. The miss isn't too bad now either - weird. Just every now and then it'll "catch" while idling... just a little tiny hiccup once in while. CEL is still lit. I'm in the process of deciding on a new phone, so when I do I'll get an OBD2 app and deal with it a little more. For now, I'll leave the "help I have a miss" party. Thanks for the good info on the injectors, both of you!
Austin __________ '97 LSi Ebony - daily driver - mostly just needs body work [couple o' rust holes, door dings, and peeling clear (of course)] '96 LSi, Laguna Blue (retired - soon going to a new home) '89 XT6 5 speed (Gone but not forgotten) |
A 1994 is OBD1 so that app won't help you.
Austin has a 96, in this thread it is 2 different people and cars with similar problems
If your getting your injectors serviced, I recommend Mr. Injector. Had great results with two different cars.
1994 SVX LSi JDM Tailbar and Grill, Clear Corners, 15min-mod, Nevin Blue RSB, G-FORCE SPORT COMP-2 Tires, Phenolic Spacers (Manifold & Throttle Body), SS Brake Lines, Maniac Electric Motors 160A Alternator 2008 Legacy 3.0R |
Thread Tools | |
Display Modes | |
