Old 12-26-2001, 09:29 PM
ravi
reprogamming the security system
Hi,
John gave me a book which had directions to reprogram the security system and some other stuff, but I lost the book (sorry john, can I get one again?)and I need to reprogram the security system. Can somebody give me directions ??
Old 12-27-2001, 08:27 AM
Aredubjay's Avatar
Rat Fink Member ~:o)
Re: reprogamming the security system
Originally posted by ravi
Hi,
From the Yahoo site FAQ, courtesy Terry McLane:
How do you reprogram the remote keyless entry transmitter?
This procedure is used if you need to program a new transmitter or additional transmitters. Programming is done by pressing the button on the transmitter after entering the programming mode. To enter the programming mode, use the following procedure:
Turn the security system off by pushing the security switch (light off).
Turn the ignition switch on, then off.
Immediately push the security switch on and off rapidly until the horn starts to beep; then stop pushing. The system is now in the programming mode and you are ready to program the transmitter. The programming mode is indicated by the parking lights flashing and a clicking noise emanating from the glove box.
To program two transmitters slowly press the remote button two times on each transmitter.
To program one transmitter slowly push the remote button four times.
Note: The parking lights will turn on when the button is pushed and turn off when the button is released.
To exit programming mode, turn the ignition switch on, then off. The parking lights will stop flashing and the system can be used normally.
What battery fits in the remote keyless entry transmitter?
Radio Shack #27-279 GP27A. This is a single replacement for the multiple batteries required originally.
Randy Johnson
Mike Davis -- at Reading VI
Old 12-27-2001, 07:58 PM
ravi
thanx arub ( did you mind that short name?)
Old 12-27-2001, 10:45 PM
Aredubjay's Avatar
Not at all, just keep the "e" and "d" in it (aredub). Otherwise, people might get the wrong idea. I suppose we've known each other long enough that you can call me by my "familiar" name.
Randy Johnson
Old 12-29-2001, 07:09 AM
montypython montypython is offline
Is it Summer yet?
I don't use my SVX as a daily driver. It gets spoiled, garaged and sometimes covered and sees day light usually only at weekends.
However, due to a lot of travelling on business and a trip to the UK it recently went 6 weeks without use. Needless to say the battery was flatter than a pancake.
Now the security system is inoperative. I get no response from the remote at all and the light on the button glows continuously when in the on position. I have not even attempted to do the reprogramming yet.
This happened one time before when I had the battery out to do a spark plug change. Then I went through all the motions of reprogramming but without success. A couple of weeks passed by and for no apparent reason it began to work again.
I'll see what happens this time.
Colin
96 SVX LSi 85K (Sold)
04 Legacy Sedan 121K
06 Chevy Malibu 71K
13 Outback 0K
Old 12-29-2001, 01:35 PM
Aredubjay's Avatar
Colin, try to carefully "document" every phase of your diagnostic. This seems to be a common security system problem. This is what mine was doing when I thought it was kaput. Your work could be critical to the "cause."
Randy Johnson
