Let's talk Brembo 4 pots
Ok... We found out the brembos bolt to our hub. The 5x114.3 rotor also lines up with the caliper on the hub. the dilema is that the caliper is held away from the rotor too much. Thanks to Jman050 I was able to measure what we have here and I know what we will need to make the 4 pots work.
The stock Sti rotor is about 12.8" in diameter... Not too shabby. The stock Sti caliper is .510 inches or 12.95mm too tall for the Sti rotor. SO this means we need a rotor to be 1.02 inches wider in diameter or 25.90 mm. Do some research for me and try and find a rotor with the same offset dimensions as the Sti with a diamter of 13.83 inches in diameter with at least 60mm of surface area. It needs to be 30mm thick too. tom |
I checked DBA's database and they don't list any 352mm rotors with a 53mm height 30mm thickness and 58mm center with 5 lugs. I sent them an Email asking if we could find them. I will let u know more when I do
Tom |
I posted up over at the Grassroots Motorsports board, I'll let ou know if I learn anything...
tom maybe we can have them made,?
did we find out if the 350z//evo//sti are all the same brembo caliper part#s?
2008 evo x with sss package 430 hp 380 torque stock turbo with basic bolt ons 12.56 @ 109 fully weighted 3,500 lbs |
Thats not as far off as I expected. But hopefully we can find a rotor solution and open up our brake possibilities.
[SIGPIC][/SIGPIC] STi BBS wheels,legacy gt 4.44, 3" catback exhaust, Stance GR+ 7k/5k, QS Teflon adjustable endlinks, Hankook EVO 245/40/17, 95-LS escaine seats, GC8 V7 steering wheel, JDM clear corners, small car clear lenses, Alcyone badge, JDM rear taillight, 97 grille, stevesby bumper, PWR radiator, Perrin Crank pulley, Urethane Swaybar bushings, urethane diff bushings, DDM 6k 55watt lows and 4500k 35watt fog lights; $15/15min mod, Motorsport whs 22mm rear swaybar, QC shift kit, ToMyx intake, z32 aluminum calipers 13" rotors, nitrous express proton + wet kit. |
Does that .51 inches really not allow us to use a 17inch wheel?
Would 355mm work? Most of the big brake upgades for the STi use a 355mm, and I'm sure you could probubly get the rotor by it's self. |
possibly but there may be clearance issues on the caliper
Tom |
What about custom rotors according to our specs? Maybe a group buy?
been there done that! i am just kidding guys.
see tom now you now what i am talking about i wish it would have worked but it wont. and just think we are on the front and the rear is next, who knows what is going to happen in the rear. i think we have a better chance with the wrx 4pot 2pot on with brembo rotors and 17inch rims will clear becuse the stock svx rims all most worked when we tried it.
95 impreza sedan L (aka 91 legacy turbo: ej22t DOHC 22B +400whp@20psi spec-C 6mt RA) hand built by Subaru TecNICO International need i say more. |
How about a Dodge Magnum rotor with 345dia/55ht/28thk? they are 5x114.3
EBC rotor catalog: http://www.ebcbrakes.com/Assets/discdrum2007.xls Quote:
'93 Anniversary Edition SVX 122k - 3.7 FD 5MT Swap, ECUtune 1a1, Bontrager RSB, Mad Restoration underway! '20 Honda Ridgeline Custom Oil Caps, Battery Bars, Phenolic Spacers for sale here: http://www.x35design.com Last edited by Stevebsy; 03-19-2007 at 09:40 PM. |
thats 7mm too small. Not to mention, my measurements have shown me that the calipers will not effectively support a rotor larger than the STi rotor. Check the thread in my sig for the Brembo group buy, they are an even better deal
Tom |
NO idea what it looks like in there but what about trying to use a whole STi front hub? Just i screwy thought..
- 2005 WRX STi, Crystal Grey - 1992 SVX LSL Touring, Pearl |
Do you really think we would have done all this research if we could just use the hub??? No the strut mounting points are different as well as other things
Tom |
Someone has got em... I need the dimensions to the Sti caliper from Brembo... where can I find those??
Tom |
