1/4 mile???
ok I have being think of going up to the Drag way to see what i get on my car ??? What has evey one got on it?? I'm just about stock But i have tires,light weight rims rottors new lines and pads. If i go up there i'm going to take the back seat out and the Grill too
15.5 or slower more than likely.
15.6 with a bad / no launch in a FWD L model. Your lightweight rims and seat removal should bring you pretty close to this
R.I.P Cool Signature. You're gone but not forgotten. I mean, sure, I kindof don't remember some of the finer details..but I remember you were funny, and at one point you said spaghetti in Dutch....but definantly not forgotten |
should the Cars get likt a 15.2 or something like that All stock out
I think most people are getting about 15.6ish bone stock. The wheels and taking the seats out might get you one or two tenths off
Let us know what you run when you go
Short answer...No Chike holds the current "stock w/4.44 gears" best time of 15.063. The earlier comments about mid to high 15 sec. times are about the best you've got to expect, depending on outside temperature and the condition of the track. Make sure to have the amount of gas in your tank below 1/4 of a tank to get the overall weight down even more. Good luck! Make sure to post back with your time along with the outside temperature and the actual location of the track you run at. -Bill
Retired NASA Rocket Scientist Most famous NASA "Child" - OSIRIS-REx delivered samples from asteroid BENNU to Earth in Sept. 2023 Center Network Member #989 '92 Fully caged, 5 speed, waiting for its fully built EG33 '92 "Test Mule", 4:44 Auto, JDM 4:44 Rear Diff with Mech LSD, Tuned headers, Full one-off suspension '92(?) Laguna, 6 spd and other stuff (still at OT's place) My Locker Last edited by SVXRide; 04-29-2006 at 02:24 PM. |
Are you serious about removing the grille? For the work involved I don't think you will get much of a result from removing the grille. Take out the spare tire and everything else from the trunk. Clean out everything from the interior. I have seen ten pounds of CD's in some cars! Get as much weight out of the car as possible. Since you don't have to worry about tire grip, I would put about 40 psi in all my tires to decrease rolling resistance. Put about 1/4 tank of fresh, 93 octane gasoline in your tank, along with a can of octane booster and be sure your oil is fresh and clean, not overfilled. Clean or replace your air filter. Run a can of injector cleaner through your engine a few days prior to going to the track. Make sure your ATF level is full. One more thing, if you normally drive conservatively, a few days prior drive your car hard, get on it from a stop and let it reprogram the ECU to better suit your needs at the track. Good luck.
Preston |
Well if I remove the grill that would make me a few gr. lighter and Puls I would get more air into the engine. The gas I use is Shall V-power. I need to run the car allot more before I go up there so it well be ready for the run.
I’m going to run at Alabama's Steel dray way. The thing that I’m trying to go for is bet a 01 Rs Unlike that I will bet him but well see what happenings but you never know Also need to get the car ready for its first rally cross or a auto X come up On the 7 in Alabama. Last edited by Crazypolo95; 04-30-2006 at 09:36 AM. |
i hope everyone understands octane booster goes up by points of octane, like from 93.0 to 93.1, and it is very bad for fuel injectors, it almost likes to clog everything
all that work and possibly damaging the svx for a mid 15 second run ?
buy something fast
2008 evo x with sss package 430 hp 380 torque stock turbo with basic bolt ons 12.56 @ 109 fully weighted 3,500 lbs |
