Old 01-27-2015, 12:51 PM
AdamG AdamG is offline
Getting started
I bought a 1994 SVX LSi 2 weeks ago. 230,500 miles... it works for the most part.
Questions:
How hard is it to change the valve cover gaskets?
Same thing for real wheel bearings
When I start to turn the wheel (about first complete circle) it sounds like there is grinding coming from the back of the car... possible problems?
Where do I get parts for this bad boy?
Car is originally blue. Rear spoiler paint is shot... best tips on sanding or stripping down so that it can be primered for a while?
I will post pics soon...
Old 01-27-2015, 01:12 PM
halistan's Avatar
halistan halistan is offline
Grand Poo-Bah
Send a message via AIM to halistan Send a message via MSN to halistan Send a message via Yahoo to halistan
Re: Getting started
I can't answer all of these, but I know a couple.
The valve covers aren't too bad. They can be a little challenging but you can do it without pulling out the engine. It just takes a little dexterity.
The grinding you're hearing is probably the rear wheel bearing, which you say you need to replace so that will probably take care of 2 birds with one stone.
As for parts...it kinda depends on what you need. Nate Gustafson is a great resource for parts. He's 1986Nate on this club and someone you really want to get to know. He's a wealth of knowledge and can help you find the parts you need.
For new parts, you can get them from subaruparts.com as well as a few other online sites. Subaruparts.com is nice because they have a lot of the diagrams posted so you can figure out what parts you actually need.
http://subaruparts.com/parts/1993/Su...40&searchText=
'93 LS-L named "Samantha Victoria Xavier"...Sam for short.
All new and improved custom built engine with forged internals, lowered compression, upgraded cams and a stage III supercharger. AMR Engineering struts, Custom exhaust --All 3 Subaru cats removed, and replaced with 2 high flow mustang cats-- Cross-drilled & Slotted rotors, steel braided brake lines, bypassed stock Tranny cooler replaced with aftermarket B&M super-cooler, and a K&N drop in air filter.
Old 01-27-2015, 06:58 PM
Tapani Tapani is offline
Re: Getting started
Hi Alan,
We're all SVX-a-holics too, so welcome !
There's a ton of rear wheel bearing info available - use the search function. They can be a bit tricky, but I've done them - so you can do them too .
The rear wing is fiber glass - there's good info on repainting and fixing it in the factory service manual.
You can find all sections here: http://phantomotaku.com/SVX/
The grinding noise can be a number of things - check the brakes too. A friend could listen outside when you're driving in circles.... you may be able to get more info that way.
Kind regards from Finland,
Tapani
