Old 12-18-2012, 02:42 PM
madmike madmike is offline
Heater control issues
Has anyone come across heater control issues like i am having..
What happens is the temp setting keeps rising up to its max. If you hold the temp lower button it will go down but as soon as you stop the temp rises up to max again....
Not great when the SVX is the summer cruise car...
We are taking it up from Palmy to Whakatane for new years and i would love to sus it out before then..
Current Subaru collection stands at 4
1990 JDM RS Turbo. (the rally car..)
2002 GT30 wagon (racecar tow car)
1998 WRX STI.. The girlfriends car
1992 SVX.. The summer cruise car
Old 12-18-2012, 02:55 PM
dragoontwo dragoontwo is offline
Re: Heater control issues
first thing that comes to mind is: if you push up on it, do you get the same feel as pressing down? A feeling like the up switch is stuck and not giving you a positive feel?
'92 SVX LS Pearl White - 6mt
Old 12-18-2012, 04:20 PM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
Sounds like the same issue that I was having last year - mine fixed itself, but there is a japanese site somewhere suggesting that all the electrolytic capacitors should be replaced -
http://genmei.itline.jp/~svx/diary/?date=20040912
not sure if it is still around?
Old 12-18-2012, 04:33 PM
That is a known problem with that type of Aircon unit. Capacitors age and leak to cause corrosion of the board.
You can read about the fix in these posts. The link to the Japanese fix, reads ok by Bing.
http://svxworldforums.com/forum15/3114-1.html
And here.
http://www.subaru-svx.net/forum/showthread.php?t=52387
Old 12-18-2012, 07:51 PM
Yeah it feels the same when you push either up and or down....
I might have to pull the console out and have a decent stripdown look..
Lucky i have a set of the factory Subaru manuals to help..
Old 03-15-2014, 11:19 PM
SURTEESS's Avatar
I did a "how to" on this - sent it to one of our members, but it has not been posted yet?
Old 03-19-2014, 03:48 PM
SURTEESS's Avatar
Still waiting for the "How To" to be posted ...... check with Earl as to how long it is going to take him to "re-format" the PDF.
(the original Word Doc is 90 Meg - far to big to email.
ensteele@gmail.com <ensteele@gmail.com>
Old 03-20-2014, 07:52 PM
ShaneHobson ShaneHobson is offline
do you want to send it to me to fix up ?
I used www.ge.tt to send a 135MB file to someone, worked easily.
Old 03-23-2014, 02:50 AM
SURTEESS's Avatar
Shane - sending through now...
Note that the C9 cap may have same effect for temp up as temp down ?
